Question about Kenmore Washing Machines
I a looking for a water temp switch part # 3349589
I am looking for a water temp switch part # 3349589 for a Kenmore model 110.82874100. The machine will not fill on cold water unless you puch in on the water temp button. The part is discontiuned from Sears. As an alternative, can the switch be fixed??
Jimster
  • 240 Answers
SOURCE: Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Posted on Oct 17, 2007
  • 1294 Answers
SOURCE: wASHING mACHINE #82874100 110 SERIES
You need a good pair of grip pliers for the job. Release the grip, push further into pipe, fit pipe maximum into connection, grip clip again & clamp it over the rubber & connection. A proper grip plier is the key........
Posted on Dec 02, 2007
  • 156 Answers
SOURCE: Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Posted on Feb 27, 2008
  • 1314 Answers
SOURCE: water fill temp.
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
Posted on Mar 27, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
Pressure switch for a kenmore model 11047789701
Hi.
The original part (p.n.W10415587) is scarcely available . A replacement water level pressure switch can be used in place of the original.
Pressure switch.
KENMORE ELITE Residential washer Parts
Kenmore Elite Water Level Switch-Forum Discussion
Regards.
Ginko
Dec 15, 2011 | Washing Machines
.how do you remove the water temp knob from this
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082873810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts. Look at the section on the console.
Next see the following for how to release the console for access to the knobs / switches.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6b1f4b747e3f6a996f7dbf25034cd5f4
Also see the following Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 14, 2010 | Kenmore Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
I have a Kenmore washer. the water temp switches by itself.
IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Kenmore heavy duty washing machine 70 series
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
402 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
