Question about Samsung SMH7178STD Microwave Oven
The microwave' ligths and everything else are on, but it doesn't start working. This hapened after I had my grand children overnight...
  • 1,476 Answers
Don't know that they had anything to do with the problem. When you say it doesn't start working I assume you mean lights come on, time counts down, fan runs but no heating occurs. If that is the case something has failed in the power circuit. Microwaves have a HV diode to rectify the AC to DC for the magnatron. 99% of the time this is what fails. When microwaves were expensive I used to fix a dozen a week with this problem. It usually blows because someone ran the unit with nothing in it. If there is no load for the heat it will build up in the magnatron and eventully the diode will blow. It could be something else but this is the most common problem and not an expensive fix.It probably is more than the average owner would want to tackle but a reputable appliance repair shop should be able to fix it quick and cheap.
hardrocko
Posted on Feb 01, 2010
I replaced the line fuse in my GE JVM1790SK01 microwave, but it blew again as soon as i tried to start it. the display came on, but blew the fuse as soon as i hit start i start.
Yes... Not very sophisticated... but that is what these beauties do when their Magnetron finally gives up the ghost (major cause).
They are wonderful machines!
Magnetron
AP3883525 (WB27X10865)... approximately $104... at appliance parts pros
If you love them... you know what you need to do.
and
Fuse:
Very good... you have an excellent beginning.
Keep up the good work.
These "parts" can be EARLY failed... by putting very small
pats of butter... or ting amounts of fluid. I watched my sisters grand children using her "NEW" microwave to soften pats of butter.
A word to the wise wasn't heard... and now she has another "NEW" Microwave.
Good luck... save $$$
Jan 03, 2016 | GE JVM1790 Convection / Microwave Oven
Everything on microwave works except it doesn't heat or cook. what is the problem?
IT'S THE MAGNITRON - CHEAPER TO BUY NEW THAN REPLACE - SORRY.
Jan 09, 2013 | Microwave Ovens
Whirlpool microwave start button not working
There are 2 possibilities the first is that the button is locked. Some modern microwaves have lock buttons so children do not play with them. To unlock it you can try either holding th "start" button until you hear a tone of hold the "stop/end" button until you hear a tone. If that does not work it means that the button it self underneath of the plastic is broken or blown which means that it must either be repaired or the microwave must be replaced. For the price it may be more cost effective to replace it is the button is broken.
Sep 26, 2012 | Whirlpool RMC305PD Microwave Oven
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Samsung microwave oven smh8165st
If everything else seems to work, the magnetron is the likely problem which is the heart of the microwave oven, consideration should be given in replacing the microwave because of repair cost.
Apr 02, 2012 | Samsung Microwave Ovens
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
Doesn't heat up but everything works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';'
May 18, 2011 | Emerson Black Microwave Oven
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
May 07, 2009 | Microwave Ovens
Microwave Ovens Logo
124 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
