Question about GN Netcom GN 8000 Amplifier
I need a pin-out for the headset. Any help there?
I need a pin-out for the headset. I am converting the headset (through an adapter) to a 2.5 mm headphone jack. Any help there?
My gn flaching all the way
Posted on Feb 03, 2010
How do you connect tv audio from vizio wv26l through panasonic saht 680 surround sound?
The SAHT680 only has RCA analog audio inputs. I don't know the WV26l. However, there are a couple of possibilities based on other Vizio models. 1) The audio out is a headphone jack. Use a 3.5 mm M to RCA F/F adapter and then an RCA audio cable to the surround sound system. (You can also use a cable that has the 3.5 mm M and RCA M/M ends or a 3.5 mm F and RCA M/M adapter with a 3.5 mm audio cable.)
2) The audio output is a digital audio out. In that case, you need a digital to analog audio converter. There are a number of models available. One example is here: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2 . You will also need the correct digital audio cable between the TV and the converter and the RCA audio cable between the converter and your SAHT680.
The manual for the SAHT680 is available from Panasonic here: service.us.panasonic.com/OPERMANPDF/SAHT680.pdf . See page 25 for the picture of the audio inputs.
I hope this helps.
(The only other option is to upgrade the main unit of the surround sound system to one with digital audio inputs if your TV only has digital audio out.)
Nov 19, 2012 | Audio Players & Recorders
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
What type of connector do you need for a wired headset? samsung gravity 3 phone
Hi!
The headset need a samsung proprietary type of connector, but:
I recomend you a very good alternative to that, a adapter allowing to use any regular headphones with 3.5 mm jack:
Here is an example for such an adapter:
http://www.amazon.com/dp/B004S6LSSK/ref=asc_df_B004S6LSSK1660421?smid=A10KOAR5YA65RL&tag=dealtmp1-20&linkCode=asn&creative=395105&creativeASIN=B004S6LSSK
Please let me know if it helped.
Best regards
Aug 10, 2011 | Samsung Cell Phones
I have a dp15657 19" sanyo it doesnot have the 15
Possibly. If your video card has a TV-out capability, you can do it directly with the appropriate connector. This adapter may have shipped with the video card. Check the specs, only some cards do this.
Otherwise you need a VGA to composite video, VGA to S-video or VGA to component video converter. See http://www.svideo.com/vga2video2.html for some samples. Do not just use a VGA to component video cable; those are for connecting to a projector that interprets VGA RGB signals.
If you want to use the TV speakers you will also need a 3.5 mm stereo (male) to RCA stereo (2 male plugs red/white) adapter unless you get a converter that includes this in the unit.
I hope this helps.
Nov 13, 2010 | Sanyo Televison & Video
Microphone doesn't work with small plug
I'm just taking a stab in the dark here but bare with me on this, I got a lot of info stored in this old head so it takes a while.
If you look at the jack for the microphone, Does it have 2 sleaves and a pin or just 1 sleave and a pin. If it has 2 then you will need an adaptor (Normaly Stereo jack to XLR). If it has 1 sleave then your going to need a preamp.
Apr 20, 2009 | Computers & Internet
Finding a adapter pin for motorola
Hola
no creo encuentres ese adaptador, Talk about utiliza un plug stereo de 2.5 mm, el audifono que mencionas tiene dos plugs uno de 3.5 mm Mono y uno 2.5 mm stereo.
Tendras que hacerlo y cortar el cable y utilizar un plug 2.5 mm
Jan 18, 2009 | Motorola 2 Pin Adapter 2-Way Radio
LG Trax Phone - headset adaptor
I recently bought a similar adapter for my trax and had the same problem. Taking the plastic cover off of the adapter, I found the following on the back of the 18 pin connecter: a jumper from pin1 to pin 11, a jumper from pin 9 to pin 10. audio l and r wires to pins 14 and 15, common audio wire to pin 18 and unconnected pin at pin17. By accident, I found that if the unconnected pin 17 bent over to touch the wire to pin 14, the headphones started working. So, solder a wire to connect pin 14 to 17 reinsert these pins into the correct slots and you have a working adapter.
Dec 26, 2007 | LG CU500 Cellular Phone
GN Netcom GN 8000 Amplifier Logo
417 people viewed this question
Top GN Netcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a GN Netcom Audio Player and Recorder Expert? Answer questions, earn points and help others
