Question about Belkin N Wireless Modem-Router F5D8633au4A
I have lost connection to the internet on my lap top and 2nd desk top pc. The Belkin "N" router has all the lights on as normal??
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Posted on Jun 19, 2008
YourTech
  • 63 Answers
SOURCE: belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Posted on Oct 06, 2008
compucure
  • 61 Answers
SOURCE: Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Posted on Mar 20, 2009
  • 8 Answers
SOURCE: Belkin N1 wireless router drops offline
The connectivity issue with your Belkin router could be due to a couple of different items. Your ISP might even be able to shed a little light on the subject.
I would also go to Belkin's website, and go to the support area by clicking on Support Center in the left pane of the sight. You can then search for your product number. With the results that you receive, you will be able to see what version of firmware they have, which is like doing a software upgrade on your computer. There should also be a step by step process on the website for you to install the firmware. I would do it from a desktop that is connected physically to the router.
Please let me know if you would like further assistance with this matter. Thank you.
Posted on Mar 27, 2009
  • 93 Answers
SOURCE: My Belkin G Wireless Router cant even get passed
Since your unable to access internet through the router(wireless) ,& globe light is flashing--I suggest you to refresh the network list and connect to your network again still if it won't work then you need to Re- configure it. Because your Modem(cable/dsl) is working fine. Check the ip address of your computer. if its invalid then you need to do the "reset" on router (ip address should be 192.168.2... range).
Or else you can call (toll free number) for belkin for reconfiguration
Hope this suggestion helps for you both...
Posted on May 31, 2009
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
I have just purchased a belkin cable rooter n+wirless rooter, I have two questions 1 - Set up secruity word router attached to wired pc. wirless lap top can connect but does not ask for password. why is...
1. Belkin makes you not only setup the wireless/WEP but you have to turn it on as well. (radio button I think) Some also have a separate configuration for N vs. B/G, since it does both. check your setup
Look under "Wi-Fi Protected Setup" in the configuration.
2. This is normal, that's your power light.
Dec 09, 2009 | Computers & Internet
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I lost my setup disc's and I am trying to set up my internet so that I have my xbox hooked direct and my lap top is wireless
get another computer with internet connection and google your router... Example: belkin f5d7231-4 driver
This should brink results with links to the required drivers that your router needs.
Jun 29, 2009 | Belkin (F5D8231-4) Wireless Router...
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Belkin connection issue with 2 nd lap top
Hi iam router technician i understand your problem very well..To fix this issue all you have to do is,
First Confirm the model number its(starts with F5D & version (starts with VER) of your router and check for FIRMWARE update.
It may be quiet difficult for you to do up date firmware.please call toll free number"belkin" and ask them help you to update it..
..........Hope this information is help full for you ALL............
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Laptop
the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
Then you should be able to see the internet from your laptop.
Jan 20, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin N Wireless Modem-Router F5D8633au4A Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
