Question about Pioneer GM-5300T Car Audio Amplifier
My amp normaly has a continuious blue light when functioninng properley now it is at a fast blink and my subs wont work what is the problem i have checked the hot and ground and the remote wire .if i disconnecet the remote wire and touch it to the terminal the amp light will stay solid for aprox 1 sec
  • 1,068 Answers
Yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Posted on Feb 04, 2010
Vibe bluetooth earbuds wont charge
That's a shame. However, this query is more for a forum dealing with audio equipment - this forum is for Cameras.
Sep 18, 2017 | Cameras
TV model # 42631 has a continuious green light blinking rapidly
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Electro help
Jan 16, 2014 | Mitsubishi Replacement Oem V33 Pwb-dm...
Power went out and tv wont turn back on. all i get is a blinking green light next to the on button
There is usualy one of two reasons. 1) The DM board has failed. 2) The convergence has shorted and is causing the TV to shut down. Normaly if its just a fast blink its the DM. If its blinking a pattern or error code of 22 its convergence. On the site www.TvRepairKits.com you can find out how to get the error codes and also the parts.
Dec 22, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red and blue light flash on and off
ITS IN PROTECT MODE. EITHER ITS BLOWN OR THE SUB IS TRYING TO PULL TOO MUCH POWER. UNHOOK THE SUB AND SEE WHAT HAPPENS IF THE LIGHTS STILL BLINK THEN AMP IS BLOWN. IF THEY STOP BLINKING AND ONLY ONE STAYS ON THEN LOWER THE SETTINGS ON THE AMP AND TURN THE BASS AND VOLUME DOWN ON THE DECK TO LOWER THE AMOUNT OF POWER BEING PULLED FROM THE AMP.
Aug 18, 2010 | JBL Car Audio & Video
My amp indicator is blinking blue and my sony xplod sub is not workin thru the amp but works wen i connect it in my other car how do i fix it so my light stops blinking, and my sub works again
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 03, 2010 | Kenwood KAC-X650D Car Audio Amplifier
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
No power to subs
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
May 06, 2008 | Legacy Audio Blue Diamond LA1880 Car Audio...
Pioneer GM-5300T Car Audio Amplifier Logo
334 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
