Question about Nakamichi SoundSpace 5 Shelf System
110v - 240v
I have just got my Sound space 5 system from the US and i am in the Uk. I plugged my own plug into the power supply socket and the power supply hummed then blew the plug fuse it done the same with another plug i tried.
all the specs say it is compatible with 240V. Can anybody help
I have had the power supply checked and it only blowed the fuse in my plug the unit is ok. Thank god we have fuses in our plugs in the UK, I have had a variac to bring 240v down to 120v and the power supply is working on my bench at work, I am going to try and change the taps at lunch and tap in the the centre pin so i can run 240v straight through. I had no idea the power supply was external. Why is this the case?
Posted on Feb 19, 2008
  • 56 Answers
Well it may be compatible but it should hav a switch on the rear side to choose either 110 or 240V.Check for this but you probably burned primary side of main transformator and you'll have to replace it or to find somebody who is able to fix it
I buy My playstation 3 in u.s the power supply is 110v 1.5A. In my country the voltage is 220. Can i use 220v 150watts transformer
The playstation 3 is dual voltage, meaning that as long as you have the right cable (plug for the wall socket) it will run 100 - 240v.
I believe the only exception to the universal power supply is the PAL 60GB PS3 (CECHC01) model. That power supply APS-227 is not compatible with voltages under 220V.
Jan 19, 2014 | Video Game Consoles & Games
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
Is it OK for 240v & 110v
Hello bellm.... This shaver operates on a battery. The charger for the battery can be changed to suit the power source available in whatever country you reside. If your shaver was assembled in the states, it most likely has a 110v charger which will work when you plug it into the 110v outlets found in the states. If you buy this shaver in England, for instanice, it will come with a cord and charger that will plug into the 240v system available in the UK. Joe
Thanks for choosing Fixya!
Feb 26, 2011 | Remington R5130
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Power
Ive never had this fault but it could be possible. My first reaction is to swap the Power supply unit. or simply just check that the voltage is set correctly for your country. if UK 240v if US 110v little slide on back of power supply unit. Try plugging the power cord into a different socket first though my be you electricity socket at fault.
Hope this is some help
J
Dec 27, 2007 | Acer Aspire T310 PC Desktop
Nakamichi SoundSpace 5 Shelf System Logo
222 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
