Question about Abernook Pasquini Livia 90 Semi Automatic
Livia 90 semi auto
I have a problem with the unit developing too much pressure.  I was sent a "fix" rewire kit adding a capacitor and instructions (vague at best).   It is Livia Tech Notice # hs605 if that helps. I followed the instructions and am reasonably sure of the capacitor addition under the relay.  The instructions do not address where the leads attach that were changed and carefully routed to the relay from the presurstat.   I arbitrarily (by some thought process) attached them to the other two leads on the bottom of the relay.  This resulted in everything lighting and the pump filling the heating chamber but no heat, thus no pressure eh?   Can you tell me where the two new leads attach?
mpelley@cfu.net 319-266-0236
I got hold of Pasquini directly and they most graciously talked me through it, admitting the instructions assumed more knowledge than average.  In other words it was a polite way to tell me not to quit MY day job!
Posted on Feb 19, 2008
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Jul 04, 2010 | Abernook Pasquini Livia 90 Semi Automatic
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Converting manual to semi auto transmission . one time i read from a newspaper that there is a conversion kit will turn your manual transmission into semi automatic one. just want to find shere can i...
Do yourself a favour, and do not persue that kit. It is a sham.
There are no 'kits' that takes a manual transaxle to a semi-auto. You could investigate adding buttons to the steering wheel for up/downshifts, but you would need an automatic transaxle.
Sep 24, 2009 | 2002 Toyota Corolla
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Tooo much pressure
If you remove the top panel on the machine there is a pressure stat on the right side, with 2 wire connections going to it. That P.stat could be damaged and needs to be replaced, or the pipe to the P.stat is clogged and it cannot read the boiler pressure.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
All 3 lights on Livia lighting up with hot water use
Is this a Livia 90 semi or auto ?? It sounds as if you are talking about an auto. The autos have had a history of the cpu controller board going out. Probably going to have to take it in for service for proper diagnostic repair. Parts are not cheap and with no warranty- you don't want to start throwing parts at it to get it working right.
Jan 27, 2008 | Pasquini Livia 90 Espresso Machine
Abernook Pasquini Livia 90 Semi Automatic Logo
983 people viewed this question
Top Abernook Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you an Abernook Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
