Question about GE WSXH208A Front Load Washer
The washer gives off a musty/moldy smell. If I do not wash for 4-5 days I can smell it upstairs. Have tried 'cleaning' with javex as it says in instructions, but would have to do every 2 days to get rid of the smell. What is causing this and is there a solution?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 115 Answers
Try to make a drain with baking soda
if the problem is always ask in the room or the machine is a vacuum cleaner odor
Posted on Feb 01, 2010
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Sweet smell from refrigerator
empty it out and wipe it all down with a solution of 1 cup of white vinegar in 4 cups of water. get all of the nooks and crannies. Then finish up that part of the job by wiping the surfaces with straight vanilla flavoring.
finally remove the lower front grill and clean the drip pan..........that should do it.
Aug 17, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Jul 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
Moldy smell in washer after using it.
add about 4 cups of bleach to the washer run through the hottest wash cycle possible. allow to air dry overnight. then add 4 cups plain white vinegar and run through hottest cycles again. to ensure this doesn't happen again remove all wet item as soon as possible. any clothing items that smell musty can also be run through a vinegar wash using about 1/2 cup in the softener compartmen.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
355 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
