Question about Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2
Maax Hydromax C01 followed by E06 Error Code
After a recent use of the tub, the display continues to flash C01 followed by E06. We have reset the GFCI breaker but the error codes return when power is restored. We are still able to fill and use the tub. Please advise.
  • xmartin May 11, 2010
    My tub has the same problem. Please help.
  • gilvogel Oct 11, 2010
    After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
4 Suggested Answers
  • 10865 Answers
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Posted on Sep 01, 2009
SOURCE: We have a MAAX hydromax
I will advice you check manualsonline.com or manualnguide.com to check for the manual you requested for.
Posted on Oct 20, 2010
J-Chris Ward
  • 731 Answers
SOURCE: We purchased a home with the Maax Hydromax
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=27963&ven=3726866
This is the only site i could find they might be able to get the info for you
Posted on Feb 05, 2011
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
What does CO1 error mean on my Maax whirlpool
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on, if that doesn't fix your problem, then remove the access panel to the mechanical space in your tub and there are one or two reset buttons in there which can trip and need to be reset.
May 29, 2011 | Maax Calla 7242 Hydromax Whirlpool -...
I have a MAAX Hydromax - not sure about the model #. The blower and circulation pump no longer engage. At first the problem was intermittent now it will not work at all. I tried to trouble shoot the...
yes. search US Parts Center for a solution. They will want to know the model number of your pump and model number of the controls you have.
Most likely it is a bad circuit board in the control box that turns the pump/blower on/off.
Jan 25, 2011 | Home
E06 error--how do you get rid of flashing this error and what causes it in the first place. Thanks
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Feb 10, 2010 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Maax infinity hot tub error code clfl dont have the manual
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Jan 26, 2010 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
Sep 01, 2009 | Maax PALACE DROP-IN BATHTUB - 100082-000-B...
E06 on newly installed maax calla
E06 is the water sensor, The tub will not operater if there is not enough water in it. If the water level is not the problem, it is most likely a bad water level sensor.
Jun 03, 2009 | Maax Calla 6042 Bathtub - 101058-000
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2 Logo
965 people viewed this question
Top Maax Plumbing Experts
Steve
obsteiner
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
