Question about SanDisk Sansa e260 MP3 Player
I can't load songs, playlists onto my sansa e260. I loaded the latest firmware, still nothing. Is there anything I can do. media player no longer recognizes the sansa.
  • 4 Answers
SOURCE: Media Manager
I don't think so. the directions say to use windows media player
Posted on Jan 04, 2008
SOURCE: Sansa m250 Playlist help needed
Found an answer - look here:
http://reviews.cnet.com/mp3-players/sandisk-sansa-m250-2gb/4864-6490_7-31565927.html?ctype=msgid&messageSiteID=9&messageID=1672505&cval=1672505
Posted on Apr 07, 2008
  • 5 Answers
SOURCE: Sansa e260 How to delete songs ?
This MIGHT fix the problem: Make sure that Windows Explorer is set to show hidden files and folders. In Windows XP, click TOOLS, FOLDER OPTIONS, VIEW and make sure you have selected "Show hidden files and folders".
Posted on May 24, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa e260 says connected but device not recognized
Substitute REC fo volume + in the following:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
SOURCE: Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Posted on Feb 11, 2009
My Sansa e260 can't read sdhc cards
From what ive found the max expansion card it supports is 6gb they might offer support for higher capacity cards with a firmware update but as of right now no they don't
Nov 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260, apparently wont read songs i put on it
hi
do not download songs from Windows Media Player 11
Experience
can you
Fetch songs from a CD or a Web site or your friend and see if his Will play
Jan 15, 2009 | SanDisk Sansa e260 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e280 will only charge when connected to my computer
Get the Vista compatible software from Sandisk's website
Sep 07, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e260
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 15, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 4GB mp3 player
corrupt database
-Tha Mp3 Doctor
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Downloading from media player to my sansa280
What I would recommend you to do is to update the firmware on the device...That will solve the problem you are having..It sounds like the firmware is corrupted.To update the firmware go to...
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
P.S. Please rate accoringly
Thank You
Computerrep
Feb 02, 2008 | SanDisk Sansa e260 MP3 Player
Space
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Dec 08, 2007 | SanDisk Sansa e260 MP3 Player
Loading playlist
The XP Drive letter assignment has nothing to do with Playlists. You need to set the device mode to MSC. Settings>Mode or USB Mode>MSC. Then in Windows Media Player (version 10 or higher) enable auto-sync for the PLAYLISTS only, unless you want all the music force fed to your device everytime you connect. You can add to this question for additional assistance. Best of Luck.
Oct 01, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
or
-Tha Mp3 Doctor
Sep 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
