Question about Kenmore 42822 Front Load Washer
Kenmore HE3 mod 42822 cycle light flashes but will not start cycle no codes are shown
  • 1 more comment
  • cherdon78 Feb 01, 2010
    there is no option & select button on this washer
    I tried both of these options twice, nothing happened
    There are five wash cycle buttons surrounding the start button.
    When you select any of these buttons the light on the button flashes
    when you push the start button the machine does not start the wash cycle
  • Kenmore Master
  • 2,605 Answers
Let me see if I can walk you through a diagnostic cycle. There are several ways to do this, I'll start with the most common, then the second most.
1) close the door (Do not turn on the power)
2) select the drain/spin cycle.
3) select "no spin" at the spin speed setting's.
4) push the "prewash" button 4 times within five seconds. If entered successfully, the unit will display "00" in the display, then the door will lock and diagnostic will begin, it takes approx. 5 mins. (if your machine does not have the prewash selector, we'll need to do the second option for diagnostic's).
The second most common diagnostic entry is done like this...
1) close the door but do not power unit on. (If following your previous attempt, open and close the door before proceeding)
2) Select any button EXCEPT either of the pause/cancel, stop, start, or power, depending on your options.
3) In this sequence...
a)push/hold this button for 3-5 sec.
b)release 3-5 sec.
c)push/hold 3-5 sec.
d)release 3-5 sec.
e)push/hold 3-5 sec.
If entered successful the unit will display "00" for 5 sec. then display any error history, control board version's etc, then enter the diagnostic. before beginning the door will lock, the display will go from "01" to "08" in sequence for a period of approx. 5 minutes testing all the component functions. If there are any error's or fault's, the unit should provide a code, i.e. F23, F20 etc.
Let me know if any of that help's to move you forward in a workable solution.
Good luck.
macmarkus :)
Posted on Feb 01, 2010
  • Mark MacDonald
    Mark MacDonald Feb 01, 2010
    Ok,
    Let me ask you than, which cycle light is flashing ?
    macmarkus :)
  • Mark MacDonald
    Aww ! This would indicate you have a defective door lock mechanism/latch or a connection is bad/loose to said switch/latch. This may require calling in a pro appliance tech, it's your call. It is a pretty easy repair in my opinion, (just have to remove the door gasket spring and 2 screw's holding the latch, attach the connection's and your done). but I do this for a living.
    The part number is #8182634 and retail's for approx. $50, but I'd shop around you may find it for less at a local brick & mortar appliance parts vendor or on-line.
    Let me know if I can assist you further.
    Good luck.
    macmarkus :)
    Brigadier General:
  • 3,917 Answers
Try pressing the "options" and "select" button until the lights goes away.
Or if it doesn’t solve the issue, it is probably because of blocked pump. Take the back panel off, access the pump and the outlet pipe, clean it and your washer will start working.
Thanks for contacting fixya.com
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore HE3 42822 powers off during cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 08, 2009 | Kenmore 42822 Front Load Washer
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
May 01, 2009 | Kenmore 42822 Front Load Washer
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 model 42822 flashes HF??????
probably fh ..be sure drain hose is at least 30 insches from floor and fits loosely in standpipe to prevent siphoning also ckd all fill hoses for obstructions in inlet valve ends most likely problem is flowmeter remove top round object left side with 2 small hoses try tapping it this may at least let you know for sure it is problem even it doesn't flowmeter is most likely the problem
Nov 20, 2008 | Kenmore 42822 Front Load Washer
Kenmore 42822 Front Load Washer Logo
91 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
