Question about Belkin F1DG102U 2-port KVM Switch
Power light went off
- is there a battery?
No, the switch is powered from the keyboard connection on your computer.
Posted on Feb 06, 2010
Battery warning light came on while driving, but went off again
Your alternator may be on its way out. The red light tells me there are times when there is no power going to the battery. My suggestion is get it looked after or it will let you down on the road as the battery will die with the lights and engine drawing a lot of power.
Jun 14, 2017 | Cars & Trucks
Power to amp but no light happened when my battery went dead replaced
the power amp has a short in the unit and it drain everything out of the battery, that why the battery is dead. it is really possible that a capacitor is open or shorting out cause the unit to drain the battery.
Mar 26, 2014 | Volfenhag ZX-8400 Car Audio Amplifier
2002 saturn no electrical power nothing works
If you are using a self powered test lamp you will get them results but if it ground to power you have a power cable shorted to ground.
Apr 26, 2017 | Saturn Cars & Trucks
Battery and break indicator showed up and power steering went out all at the same time
Are you sure the drive belt is still on the engine ?
The battery light usually comes on when the alternator is not charging the battery, and the power steering is also belt driven.
The brake warning light can come on when the brake fluid is low, but also when the battery light comes on.
Jul 24, 2012 | 1995 Isuzu Rodeo
My Hp Pavillion dv60000 went through a power surge during a storm.
From the description the power surge went through the power adapter and into the main motherboard, I would have the power supply checked out, if okay! it means the motherboard has been compromised and at this point replace the laptop computer
Apr 14, 2012 | Microsoft Computers & Internet
Car lost all power when using emergency brake - stopped using it and everything was OK - a week later went to start car and when turning key was totally dead - friend went to give me boost and when he...
Welcome to FIxYa.com
Check for a drain remove the positive side battery connect a test light clamp end to the battery wire and the pointed end to battery post light will be on. Pull one fuse at a time. When test light :light goes out that is the circuit draining the battery
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 21, 2010 | 1999 Oldsmobile Alero
Power steering went out on 2000 VW Golf - Battery ind. light on.
hi, if the 2 problems happened at the same time then probably your alternator belt has broken, as the power steering is also run off the same belt
Jul 24, 2010 | 2000 Volkswagen Golf
Battery drained, low engine power light on, engine light on
battery likely not holding strenght, light will stay on as a reminder of the problem, disconnect the negative cable of the battery for 5 minutes and reconnect it, this reset the error codes ( that is what the light is, an error code), good luck
Jun 02, 2009 | 1999 Chevrolet Corvette
Screen black and drive not running. No lights except ON which didn't turn off. Removed bat...went off. Replaced bat and only Power light came on.
Have you checked the Function Key combinations that switch your display to an external monitor, from the laptop's monitor?
May 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Belkin F1DG102U 2-port KVM Switch Logo
57 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
