Question about IBM ThinkPad R40 2722 Notebook
CD driver not listed in device manager
I can not run my DC-ROM
the CD-tray doesn't come out(the light in the samsung CD_ROM blinks)
also there is no information about the drivers in the device manager
  • weldone Mar 05, 2008
    My burner program can't detect the dvd burner.It doesn't show up in device manager.Nor does the cd rom.What gives?
    Problem Solver:
  • 9 Answers
If the light blinks but the CDROM doesn't eject, you can try inserting a paperclip or other small object into the tiny hole on the faceplace of the drive. That will manually eject it and you can use it that way. It sounds like more of an issue of the drive being stuck than not configured properly. Does the drive show up in my computer?
Posted on Feb 21, 2008
My Samsung DVD writer's Tray open autumatically and some times closes and open again. Sampath
the drive might be getting intermittent power
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 06, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Please help me, i have a samsung r60plus, cd dvd rom cannot be detected, what should i do?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 03, 2011 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I cannot install a program because my cd rom will start. The light goes on but goes out after a secound or two.
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 31, 2011 | Samsung SN-124 (5501631) Plug-In Module...
Help i have a samsung dvd rom SH-M522C i cant read dvd anymore? what do i do?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 08, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My samsung dvd writer can't read cd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 23, 2011 | Samsung SH-S223C 22X DVD Writer SATA Black...
Sir i have samsung cd rw drive i play mp3 cd some time after i change a new disk the drive give no responce i check in my computer but there is no drive show . i install new operating system...
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | Samsung CD-RW SW-212 Burner
Disk drive will not open
make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in or
if your computer came with a motherboard disc the sound drivers could be on it
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don't forget to vote
Feb 21, 2011 | E-Machines emachines (emachinees) CD-ROM...
The disc medio tray will not open and will not run on hp g60
Hi I'm Rain ,
Ok follow these instructions to reboot your CD Rom drive.
  1. click start then My Computer .
  2. In My Computer right click the DVD/CD rom drive icon .
  3. In the list , Click eject to see if the drive is being reconized .
  4. If nothing happens repeat steps 1-2
Now when you get to sep 3 you will click properties .
5. In properties click Hardware .
6. In Hardware click the DVD/CD device to highlight it .
7. Click properties .
Now look to the bottom of that window to see device status .
If it says , this device is working properly .Properties .
Next click Driver . In driver you will see a list of option tabs that allows you to , Roll Back driver Update driver and Disable driver .
The other option is Driver Details.
Click Roll Back driver to restore the driver back to the state before you added the latest program . Click ok and follow the screen instructions.
If this fails , you can follow these steps to get back to Driver and chose
Disable Driver . Click ok if another window pops up.
Now what you are doing is rebooting the DVD/CD rom drive.
This will restart all the drivers that are associated with the DVD/CD rom
device .
Now follow all the steps again to get back to Driver .
Now in Driver you will need to click Enable to restart the DVD/CD rom
device . Reboot your system and try the DVD/ CD tray to see if it responds . If it still fails to respond you most likely will need to replace or service the DVD/CD Rom Hardware { the Tray } .
Jan 08, 2010 | HP G60-230US Notebook
Cd rom does not work
happy to help u.well does the tray come out or is there light blinking in front of it if u press the eject button.is there any vibration in it. u could also check the driver's status in my computer then. Right click and go to manage and then device manager. in that u have to reformat ur computer and install windows again.
Oct 26, 2008 | Gateway Computers & Internet
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
IBM ThinkPad R40 2722 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
