Question about Exercise & Fitness
My EXP 1000XI Nordic Track is slipping or getting stuck when I run on it. It feels like it gets stuck and makes me slip while running.
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: My nordic track exp 1000 x slips when the speed is
This is usually caused by either a slipping drive belt or a broken front roller/drive pulley. Lower cover must be removed to tighten the drive belt. There are 4 screws located on the bottom of the unit that will release the cover.
Posted on Nov 13, 2009
SOURCE: Nordic Track Treadmill Viewpoint 2800 : The belt
It needs to be adjusted as shown in your owners manual.
There are two allen screws located at the back end of the treadmill. That's where you adjust it. 3 - 4 inches of slack midpoint is just right
Posted on Nov 23, 2009
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
Exp1000 runs for several minutes
The control circuit has an overload and will shut down to prevent a fire. It may not be the Motor at all, just the circuit board failing.
Feb 26, 2014 | Nordic Track Nordictrack Exp 1000xi...
Where do I insert lube
see the video and proceed according. God bless you
Nov 25, 2012 | Nordic Track Nordictrack Exp 1000xi...
Slips when run on
see the video and fix it. God bless you
Sep 24, 2012 | Nordic Track Nordictrack Exp 1000...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
Belt slips when running
check the tension on the w/ belt,if good your motor belt is worn out.
Mar 09, 2011 | Nordic Track Nordictrack Exp 1000...
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
My nordic track exp 1000 x slips when the speed is approx. 6. We have tightend the belt and lubricated it. The motor also sounds like it is struggling.
Nov 11, 2009 | Ironman Fitness Achiever Elliptical...
Exercise & Fitness Logo
88 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
