Question about Thetford Porta Potti
We have a thetford C200cs on the motorhome we have just bought (2003). No water seems to pump, & the blue flush button doesn't seem to work. Are there any instructions availabe? The fuse has been checked & is OK. Does the led come on all the time, or only when flushed? (which it won't do) VC
Red light is just a reed switch that turns on the LED when a floating magnet inside the cassette floats up (when the cassette is full) and switches on the reed switch thereby switching on the LED. It just tells you the cassette is full and you need to empty it.
I'd say either your button or electric valve is broken. All the button does is allow the electric valve to break the seal that allows water to flow from your onboard water system.
I'll assume that the water in the rest of your motorhome is working?
So check the switch first.
You can lever off the switch/LED panel and remove the square connector from the back of the button. Get a multimeter and set it to either Continuity or Resistance (Ohms). Place the connectors on 2 of the switch pins and press the switch (the switch is actually 2 switches with 4 pins, but each pair of pins is connected together) - if you get a beep (if multimeter on continuity) or low resistance reading (if on resistance) then the switch is working - if this is the case then it's probably the electric valve. If the switch is not working, then that's your culprit.
When you replace the connecter you can replace it either way round.
Posted on Apr 21, 2010
Our c200cs only has the red light come on when it is three flushes from a full waste tank as an indication to empty it. Our van is 2008, so the model may have changed, but I doubt it.
Posted on Feb 15, 2010
My flush has stuck on, how can this be sorted.?
Close the Inlet Water valve to the Flush Tank.
Remove the lid on top of the Tank cover.
Check the link/chord connecting the flush knob and the Flush valve.
It might be broken.
Normally the Flush Tank lever, which is outside the Tank lifts the Flush valve at the bottom of the Tank.
Nov 14, 2014 | Sport & Outdoor - Others
Thetford porta potti not flushing. Can anybody advise me what i can do to correct this.
Check the bellows has no cracks and that the top rinse tank is full of water & rinse solution.
Apr 13, 2014 | Thetford Porta Potti
Toilet won't flush...seems like no power
hi i have a thetford casset toilet but my flusher is not working i have cheked fuses but i am stumped now please help
Oct 18, 2011 | Thetford Porta Potti
Where is the water pump on a Thetford C 402 C/X located and how do I get to it.......thankyou.....Mal Hughes Western Australia
hi the water from the flush holding tank is not getting through to the pump on my c402 thetford toilet . i have tried putting water in from the glass indicator tube and the the flush works . anyone got any idea what the problem might be thanks
Oct 12, 2010 | Thetford Porta Potti
Hi, have a built in thetford toilet in my caravan. The pump has stopped working. How do I check and remove the pump if required? Thanks Rosco
Don't send money. Just go to thetford.com and download info.
Some tips - if seal is old and breaking up make sure you recover all the bits which have fallen into the flush water tank. If new o-ring seal not available use outdoor silicone sealant and allow to set for 48 hours before adding anything other than a small amount of water to test flush action. Electric circuit includes a fuse and microswitch which are both contained within the flush water tank but you are unlikely to have problems with these items.
Nov 04, 2009 | Thetford Porta Potti
Casset toilet will not pump water for flush
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
May 27, 2009 | Thetford Porta Potti
When I flush, no water comes out?
Happy repairing.
May 21, 2009 | Thetford Porta Potti
Thetford Porta Potti  Logo
1,498 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
