Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Trying to hookup old dvd/vcr to new flat screen. have cable box hooked up nad working. dvd/vcr no hdmi connections. what cable hookup do I use
  • 1,476 Answers
You need to use composite inputs. They have three connections, yellow for video, white for left audio and red for right audio. It does not matter which input you go into. I would imagine there are about 7 separate inputs like the ones I described, just remember which one you use because you will have to set the input to that number to see the VCR/DVD later. Get a phono or RCA patch cable and connect the same colors from out on the vcr/dvd box to in on the tv. Turn everything on, set the tv to the proper input using the menu or input selection and you should be able to view video tapes or dvds. Let me know if you need more help.
hardrocko
Posted on Feb 01, 2010
How do I connect the coax antenna cable?
This unit doesn't have a tuner, This is what I found when researching this question for you.Maybe you can hookup DVD player or VCR player with audio and video cables, I know some VCR's have HDMI on them too that can be hooked on that TV. Good Luck
Apr 26, 2015 | Maxent MX-50X3 50 in. HD-Ready Plasma...
What kind of cords do I need in order to hook up my vcr & dvd player?
You will need to consult your manuals, or look at the hookup panels on each type of equipment.
RCA Cables will probably be used between the VCR and TV, and they may also be used for the DVD player.
25540373-ontvtplkga5hki4wstvvghil-1-2.jpg HDMI cables may be required and look like this.
25540373-ontvtplkga5hki4wstvvghil-1-5.jpg Finally, you may see a small square socket which is used for optical cables.
All you need to do is determine what cables will be used based upon what the appliance has to offer, and then procure them and hook the system up. My TV currently uses all three types.
Mar 09, 2015 | Westinghouse 32" Flat Screen Lcd Hdtv,...
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
How do I hook up my dvd player to my flat screen with a cable box
I have 32 in phliips Flat screen and I am trying to hook it up to memorex hdmi dvd/cd player
Aug 22, 2009 | Sanyo DVW-6100 DVD Player/VCR
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
1,090 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
