DVD/VCR combo won't record off of the t.v. even after programmed
I have been trying to tape t.v. shows to disc with no luck. ( I have a Magnavox ZV450MW8.) I go through the timer recording/programming process, but the next day nothing has been saved to the disc. I think there might be some confusion for me with the channel part of programming. I have satellite, so it says to select E1 or E2 for input, but it doesn't allow you to put in a number for the channel when trying to set up for timer recording. The manual says that if you have an external input, which I do, then I need to use those. Using the other choices of analog or DTV, it won't take the higher, three digit channel numbers when trying to set the timer. I'm not sure I even understand the difference between analog and digital anyway.
I have the machine set up to record a couple of shows tomorrow using the VCR, so we'll see what happens. Help!!
  • mlf0909 Feb 21, 2008
    From what the dvd tells me, E1 is the rear connection, and that is where I have my cables. I'm in the process of rechecking to make sure that everything is hooked up according to the directions for someone with satellite or cable. I don't know what a scart lead is, can u explain please?! Thanks!
A Scart lead is a high quality lead for connecting AV devices, it has 21 pins in the plug at each end. If you are using one you would need to select E1 or AV1 for the Satellite channel and you would select each Sky channel through the Sat. Decoder, not tune them in individually on the recorder.
Posted on Feb 21, 2008
  • 70 Answers
Do you have a scart lead connected to E1 or E2 on the recorder.
Posted on Feb 19, 2008
My Magnavox VCR/DVD combo groans when I set the timer recording. It doesn't make the noise when I turn it off.
I hate to sound elitist or negative, but VCR is over, much in the same way that cassette tapes are over. It is even getting hard to find DVD recorders which stand alone. Additionally, I would urge you to record all of your home movies and significant recordings to DVD while you can. VCR tapes degrade pretty rapidly compared to DVD. And now, even DVD is on the way out. Get up to speed. You'll be glad you did!
Jan 18, 2018 | Magnavox DV225MG9 DVD Player VCR
My VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Jun 11, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd when can i finalize my disc iam recording i have a magnavox combo before i starte or after tapeing
Finalizing means that you're finished and you won't be putting anything else on the disc. Finalize it after you're done so it will play on other DVD players. If you have a rewriteable DVD, then you can go back and erase it and record over it later even though you've finalized it. If you have a -R or +R only, then you can't and whatever is on it when you finalize it will be on it forever..
Dec 08, 2009 | Philips Magnavox DVD/VCR Dual Player
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
