When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
    President:
  • 2,600 Answers
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Posted on Feb 01, 2010
Dell e193fp goes blank at times
From the description there are bad solder connections on the power supply board and since the monitor is 7 years old there is a good chance some of the capacitors need to be changed.
Jul 11, 2012 | Dell E193FP 19" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor or pcu problem
It appears that your graphics card is defective. If the monitor works on your laptop and reinserting the graphics card did not help, I would suspect the card itself.
Aug 19, 2008 | Acer AL1716 17" LCD Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
633 people viewed this question
David Payne
David Payne
