Question about Kenmore Ovens
Lower element in electric oven quite working, about 12 year old
Ordered replacement element from Sears
Posted on Feb 04, 2010
The top oven stopped working 1 year ago, electricity was there, oven lamp goes on, but won't get warm, so used lower over and now it quit and for the same reason
the elements have broken down you need to replace them go to part4us and put in your oven name and model number and thay will find them for you thay also do a video on how to change them your self
Oct 27, 2010 | GE Profile JKP56 Electric Double Oven
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
No heat generated in lower oven
You are quite correct in saying that the element has failed.
As regards the wattage , it should be stamped on the fixing plate of the element, if you cannot see it there then opt for the lower wattage one, it will not make much difference to the oven ,as there is only100watt difference between the 2., and that is nothing to worry about.
Plz rate my solution to your prob.
Thanks.
Jan 03, 2009 | Neff U1721 Double circotherm Electric Oven
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Bottom oven not working
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
Aug 01, 2008 | Whirlpool GBD307PRS Stainless Steel...
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
49 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
