Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Started to preheat my oven and F-3 code came on. I cannot turn my oven off - help!!!!
  • 1,531 Answers
Is a defective sensor,electronic oven control,or the wiring in between
you need to check the wiring and make sure it is all intact with no visable signs of damage.
the best thing is to just replace the electronic oven control
Posted on Feb 02, 2010
Whirlpool gold oven message E1-F3-
whirlpool oven starts preheating then turns off and sends a message F-3
Nov 13, 2013 | Whirlpool Ovens
After i turn on oven preheat it goes to f-3
Hello there and thank you for choosing fixya
The f-3 code is a verry common code on ovens what this is telling you is that the oven temperature temperature sensor is not working correctly they normally will read the preheat then fail shortly after this and produce the code that you are recieving ok?
So you will first want to check to see that the temperature sensor is fully connected and is in good condition if it looks bad or full of grease or junk clean it and then try it again this may help but if not you will need to replace it ok?
Hope this is very helpful for you
Best regards Mike
Jun 29, 2011 | GE Profile JT915 Electric Single Oven
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
ARROW pad.
"3".
shut-off.
Thanks for using Fixya, let me know.
Jan 06, 2011 | Maytag Ovens
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Nov 25, 2007 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
62 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
