Question about Brother HL 5140 Laser Printer
Drum light will not cut off - Brother HL 5140 Laser Printer
    President:
  • 2,306 Answers
The drum light flashes when the drum is almost used up and solid when it is used up. You open the front door and hold the go button til all lights flash and that resets the drum counter. You may need also to run the blue tab on top of the drum back and forth about 20 times to clean the corona...
Posted on Feb 01, 2010
WM3885hcca. Why does the drum light stay on?
Door switch or control boards bad .
Poss. stuck button on interface control
LG OEM Part #EBR64144901 main board
Pcb assembly, display
OEM Part - Manufacturer #EBR64736201
Jul 22, 2015 | LG Washing Machines
Why 2010 toyota corolla rear wheels wont spin after replacing drums and shoes?
you should have backed off the e-brakes before you installed new shoes. if you had to hammer the drums on that should have been a clue that you did something wrong. you will have to get the drums off some way and check to make sure you didn`t install something in the wrong way.
Sep 05, 2014 | 2010 Toyota Corolla LE
Anyone know how to remive outwr glass/woid frame? Keeping inside light fixture oart snd replacing frame with drum shade.
If there's no screws or knobs of some sort it may be all made into one piece in which case the only way might be to cut it off
May 05, 2014 | Home
Dryer doesn't start. Sensor light stays on.
Does your drum light cut on and off with the opening and closing of the door
Apr 27, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I play drums, and when playing with my QC15's on certain loud sounds seem to make the noise cancellation clip and cut out audio for a second. why is it doing this?
Does this problem only happen on when playing drums? For me, when my battery is running low, if I move my head back and forth quickly or lightly tap the right headphone, they will clip in and out briefly, but replacing the battery always fixes this. My guess is that you are playing drums a lot, your battery is running low, and you might be throwing your head around violently, causing a similar problem.
Feb 15, 2011 | Bose QC15 Headphones
Brake pedal fades after starting vehicle,replaced master cylinder,bled brakes
mcdevito75 here, you:ll have to be alittle more secific with your problem, does the pedal fade at a red light?? The power brake assist will cause the pedal to fade just a shade, if your drums / Rotors were cut to often or cut too much the pedal will fade, also make sure you have brake linning
Jun 17, 2010 | 1995 Nissan Pickup
Printer cuts off 1'' off print on the right side of paper all the time. It doesn't matter what our margin settings are. What could be the problem?
Print a test page by holding down the UPPER LEVEL button for 2 seconds.
If this test page prints fine it may be a driver issue.
If the test page has the right side cut off as well then something is blocking the laser on that side of the printer. Most likely place is something around the drum cartridge area. If you are familiar with the printer and this cartridge you can try removing it and checking this area for a scrap of paper or something blocking the laser light from reaching the drum.
Oct 18, 2009 | Samsung CLP-500 Laser Printer
I can't remove the rear brake drums off my 2005 pontiac sunfire, I think because i let the bad brakes go too long and they grooved into the drums, so how do i get the drums off now/
I do brakes on these all the time.On all of the brake drums after some time they get hard to remove since the drum rusts to the axleor bearing hub. When I remove the wheel and the clips that usually come from the factory around a couple of the studs I apply heat to the drum and spin the hub.9A small propane torch will suffice since it doesn't require a lot of heat. As it warms up the drum expands and ships off the hub. Do not heat the hub or it will grow with the drum. When warm it will tap off or a light pry from the back of the drum. Without heat I cannot remove 90% of these drums.
Aug 16, 2009 | 2003 Pontiac Sunfire
Rear brake drum will not come off
It may have seized. Take a cutting torch and heat the drum, tap the drum lightly all around the drum. Keep heating and tapping until it slides off, this may take a little force but hopefully not much.
anaanymous
Oct 06, 2008 | 1998 Chevrolet K1500
Brother HL 5140 Laser Printer Logo
190 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
