Question about Compaq Presario 2170US Notebook
Cursor with independent mind
Hi there. My cursor jumps around while I'm typing. I tried uninstalling the driver, then restarting the pc to correct this, but it didn't seem to do the trick. Now I'm trying to adjust the touchpad sensitivity, but when I click on mouse properties, there's no option to adjust this. Can you tell me how to change this? Is it maybe under hardware properties/sample rate? Shot in the dark. Thanks for your help, it's appreciated. - Jen
this happens w/my laptop. The built in mouse pad itself. Any suggestions?
    Genius:
  • 3,587 Answers
Aloha..we can fix this with a shared screen session...send me an email at pn4pm@yahoo.com and it will be done in a few moments
Posted on Feb 19, 2008
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
My cursor jumps around when I am typing. On Word or any one of my email sites
Hi booghug,
Jumping cursor on your laptop can be fixed by any of the two options. It's either by adjusting some settings of your tocuhpad or by uninstalling/reinstalling it's driver.
Here's how:
  • Go to Control Panel and then click on Mouse.
  • Inside mouse properties look for the option that says, Tap off when typing.
  • Put a check mark on the box before this to enable.
  • Then hit on Apply then, OK. Restart your computer.
If after doing this you have noticed that you're still getting the same issue, reinstall the driver for your touchpad.
  • Click on th link to get the driver for your touchpad. Y410 Touchpad Driver
  • Look for Touchpad and underneath it you'll see drivers. Select the one for your operating system (ex. Windows Vista 32bit).
  • Then, click on download here.
  • Once the download is complete, install the driver for your Tocuhpad.
  • Lastly, make sure to restart your PC id the system prompted you to.
After reinstalling the driver do again the procedure in changing the properties for your Touchpad. This should resolve the problem. Hope this helps.
Thank you for using Fixya.
Sep 30, 2010 | Lenovo 3000 Y410 Laptop
The cursor jumps around while I am typing. I am using an external mouse.
Basically it may be a problem with the drivers.
So go to device manager. Click on the triangle beside the mouse. Right click on the option that comes up and click on uninstall.click ok. restart the computer. It will work.
Feb 15, 2010 | Dell Inspiron 6000 Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Cursor jumps around when typing
  1. Unistall the touch pad driver from device manager.
  2. Restart your computer.
  3. then Click Here to Download the Drivers
  4. Install the Drivers and Restart the computer.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 30, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Laptop Cursor keeps jumping
ok just to sum up the chat, uninstall current drivers, install this driver http://drivers.synaptics.com/Synaptics_Driver_v10_1_8_Vista32.exe and run it. Reboot your pc and ur ready to go
Hope this helps
JigSaw
X0X0
Aug 11, 2008 | Computers & Internet
A35-S159 keyboard problem
Try this first, Make sure the mouse cursor is further down the page or completely off the page you are typing on. Whith the problems of static electricity or stray energy if you are typing and go past where the mouse cursor is and stray voltage is present then the lightest touch of the glide pad or mouse could be interpreted as a click and your text will begin where the mouse cursor is.
Jun 05, 2008 | Toshiba Satellite A35-S159 Notebook
I've seen it happen with cordless mice. If it's cordless then try changing your batteries.
Nov 16, 2007 | Toshiba Satellite M55-S325 Notebook
Cursor problem
this is a common keyboard driver problem, go to my computer,right click>properties>hardware tab>device manager> and look down the list for keyboard, click the'+' sign, right click on the keyboard type line and select uninstall. Restart the notebook and it will automatically reinstall itself and the driver. If you still have the same problem, you will need to go to the manufacturer web site and download the latest keyboard driver if any, install it and repeat the above.
May 30, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Compaq Presario 2170US Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
