Question about Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm /... Laser Printer
HOW DO I RESET THE FUSER ON AN OKI C710 - Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm /... Laser Printer
    President:
  • 2,306 Answers
Check online for a fuser kit for your machine, OKI machines use a fuse installed on the new fusers that reset the count and then burn out. The fuse is Littlefuse #251-062
Posted on Feb 01, 2010
2 Suggested Answers
intower18
  • 957 Answers
SOURCE: how do i reset the drum unit on my oki c710?
When the image drum cartridge reaches the 90% point of its life cycle on an Oki Data laser printer, a "Change Drum" message will display on the screen. Around this time the print typically starts to become faint or starts to deteriorate. When a new drum cartridge is installed, the drum cartridge counter needs to be reset for the printer to keep track of the life cycle of the replacement.
1.Turn the printer power off. Open the top cover.
2.Press the oval switch on the operator panel. Hold the switch down. Turn the printer power on.
3.Release the oval switch when the lights on the front panel flash twice. This indicates that the drum counter has been reset. Close the printer top cover.
Posted on Sep 06, 2011
I have a OKI C710 printer that I bought from Radio Shack in Mayfield and they set it to just print in monochrome and I am wanting it to print in color again but don't know how to reset it back
They probably changed the setting in your operating system. Do you have windows or apple? Beyond that, do you recall if they made this change at the store on the printer itself, or were they tinkering with your PC when they made it monochrome?
Nov 22, 2014 | OKI Office Equipment & Supplies
Oki c710 from radio shack says "color restricted, mono printed." How do I change this to print in color?
additionally if you get a never version of English Job Accounting Server program, password that is requested is "aaaaaa"
Aug 09, 2014 | Office Equipment & Supplies
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Oct 07, 2008 | OKI B4400 Digital Mono Printer - Black
Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm  /... Laser Printer Logo
2,571 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Fix It Fast...
Fix It Fast...
Don  Farrell
Don Farrell
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
