Question about Saeco Magic Comfort 103467 Espresso Machine
Saeco magic comfort has message brew unit blocked!
Saeco magic comfort has message brew unit blocked when machine is turned on. I have cleaned the unit but the message stays and the unit will not operate.
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Posted on Apr 09, 2010
When I go to make a coffee on my Saeco Magic Comfort, it comes out in droplets from one side, there isn't a steady flow.
Have you tried cleaning the inner brewing system. Google the manufacturers website & model#. Look for cleaning unit info. I use half white vinegar mixed with water to clean the calcium from the water & the oils left by the coffee
Jan 15, 2015 | Saeco Magic Comfort 103467 Espresso...
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block).
Sep 14, 2014 | Saeco Magic Comfort Plus Espresso Machine
Hi, I have a Saeco Magic Comfort coffee machine which displays the following message when I switch it on 'Brewunit missing'. Hope you can help. Cheers
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed(food gade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort plus - brew unit miss??
Check the micro switch that the brew unit hit when it enters the machine. Sometimes the lever arm on the switch breaks off, and the switch will no longer work. Click the link for a picture of the micro switch.
Micro switch for saeco and gaggia machines
Jan 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
Water below brew unit in excess coffee tray. Over flows to counter top. Can I fix this and what will I need. Thanks, Jim
Remove the brew unit there is a small chamber under the white plastic valve, clean chamber of coffee grounds and water, there is also a small discharge to drain tray make sure it is not blocked.
Aug 22, 2009 | Saeco Magic Comfort Plus Espresso Machine
Brewunit blocked
It sounds like the brew unit is stuck with the platform tipped forward. This will prevent the dreg drawer from being put in or out. Your problem could be the result of a few things. Some you can fix, some may take more work. You can get the brew unit out by following the steps outlined on a partsguru.com, Brew group removal.
Dec 18, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing
Make sure the unit is seated properly, if any part flew off or out, it can be replaced at www.partsguru.com
Oct 13, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Aug 06, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort 103467 Espresso Machine Logo
1,534 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
