Question about Technics Audio Players & Recorders
Technics su-g91 amplifier volume fluctuates
I have an Technics su-g91 amplifier that works well except the volume fluctuates intermittently. Any idea why? Thanks.
  • 2 more comments
  • masmark Feb 05, 2010
    Thanks for your feedback. No inline tuner, just jacks for one in the rear. I tested other components on the it -- CDs and a tuner but the problem seems confined to the phono, and to date, that is all I have been trying to play on this amplifier.
    And in response to your question, the problem happens without me touching the volume knob --
    Thanks much. But can I plug the phono jack into one of the other inputs in the back of the unit such as CD or Tuner? Did try it and it made an ugly sound!
  • masmark Feb 06, 2010
    thank you for your feedback -- much appreciated.
    Sergeant:
    Champion:
  • 258 Answers
Check to see if there is a lot of dust built up in the machine if so remove case and clean with air dust
Posted on Feb 06, 2010
  • 3,740 Answers
Usually volume fluxuations are caused by a dirty wiper contact on the volume control dial.
Here is what you can do to possibly correct the problem yourself.
1. Grasp the volume control knob and rapidly rotate it back and forth from O colume to about 40 percent volume. Do this for about 30 seconds. (fan it like you mean it) Gently push on the know for a few strokesnand then gently pull on the knob for a few strokes.
2. Rotate the knob to roughly the 40 percent volume position and fan it from 40 to about 80 percent volume repeating step one for around 30 seconds while gently pushing and pulling on the volume control knob.
3. Rotate the volume control knob to around the 75 pecent volume level and repeat above for about 30 seconds while gently pulling and pushing on the volume control knob
4. Select speakers on and off with power off several times GENTLY but for about 20 seconds.
5. Perfrom the same procedure as in step 1 with the balance control.
6. This is probably not the problem but recheck the mating of the speaker wires on the speakers and the amp.
Again volume fluxuations are caused mostly from dirty contacts. My bet is you hear lots of scratchy sounds when you rotate the volume control with the speakers on. (dead giveaway your volume control wipier arm contact is dirty)
This should make a noticeable difference.
Thanks for using Fixya! Kelly
Posted on Feb 07, 2010
  • Kelly
    Kelly Feb 07, 2010
    Just wanted to add that if you have a tape monitor button on your equalizer and it is dirty it can cause the same symptoms. Mash it several times.......
    Also fan your EQ sliders up and down on each of the freq sliders for about 15 seconds to clean off the wipers.
    Lastly pull your EQ to Amp connectors off "one at a time" and pinch the outside of the metal barrel of the EACH of the RCA connectors so that it makes a tight fit on both the EQ and AMP.
    Thanks again for using Fixya. Kelly
  • 506 Answers
Does it happen when you turn the volume control or just when playing? If it happens when you adjust the volume I would say the encoder or potentiometer is going bad. You can tell if it is an encoder by the fact that you can turn the volume knob inifinitley. If it were a poteniometer it would have a mechanical stop. If it happens while playing I would say there is a potenital cold solder joint somewhere in the amplifier stages. Does this have a built in tuner? If so does it happen while listening with the tuner or just an external input source. If it showed symptoms with one and not the other you could assume the power amplifier is good and that the preamp or buffer amps for that particular source could have a problem. Let me know..
Posted on Feb 01, 2010
  • David S. Feb 05, 2010
    That is good news, that really isolates the problem to the buffer amplifier in the phono section. Your power amp is fine thankfully. Since it is an intermittent fluctuation in volume it could be a few things. However I still stand by the cold solder joint idea. Open up the unit a see if you can trace out the phono input? I have also had problems in the past with phono jacks and impedance matching between the source and input. Worse comes to worse just use one of your other inputs. Good luck man!
User manual for technics su-g91
Check the Technics website, or Panasonic, as Technics was made by Panasonic.
Dec 14, 2014 | Technics Audio Players & Recorders
Technics su-g91 muting is stuck on how do I turn it off
The service manual :http://elektrotanya.com/technics_su-g91_sch_2.pdf/download.html. i can't see it on my ipad. Too fewapps:), read it and if you don't get it, just post it . Btw. Is the mute knob a real push button or which i assume a modern click one?
Sep 06, 2014 | Audio Players & Recorders
HOW TO CONNECT SUB WOFFER TO TECHNICS SU-G91 AMP
first read the instructions they contain some amazing information. I can not help you because I have no idea of what you want. The simple answer is to run the appropriate wire from the correct output to the correct input.
Jun 10, 2014 | Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
125 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
