Question about Canon P1-DHV Calculator
Why does the lower case numbers hard to get to work? You have to keep pressing the number for it to appear on the screeen
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 02, 2010
How do i do upper and lower numbers on my computer ,i am a learner
Upper and lower numbers, or letters? I don't know anything about lower numbers. But you press the shift key or take off the caps lock to change from upper to lower case and vice-versa.
Feb 27, 2015 | Toys
Keyboard problem.numbers keep coming up on MHJKLYUIOP
That means you have the Num Lk (Number Lock)key on. And when you Press and Hold the FN function key at the lower left portion of the keyboard plus the keys you specified above the number appears instead of the letter.
Just hit your Num Lk key at the top of the keyboard to turn it off.
Apr 18, 2012 | Acer Aspire 1691WLMi Notebook
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
How to change view on cameras
pressing the corresponding number button will bring that camera up full screen. the buttons surrounding the A - B output source button will change the way your cameras are multiplexed on your monitor. you can also change which picture displays in each box including multiples of 1 camera by pressing the enter button on lower right and using the jog wheels to move (inside wheel controls up and down- outside wheel does left and right) the highlighted number where you want to put the cameras image. press the associated camera number you want there and it appears. press enter to lock the screen.
Aug 07, 2009 | GE Security DVMRe-16CT-600 16-CHANNEL...
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Numbers instead of symbols
Press the shift key to change it back to lower case.
Jul 16, 2008 | Brother GX-6750 Typewriter
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Turn off the predictive text for E250
it is the same key as to change case. If you press it repeatedly, it'll cycle through various options in the top right of the screen:
initial caps with predictive,
all caps predictive,
lower case predictive,
numbers,
initial caps without predictive,
all caps without predictive,
lower case without predictive.
When T9 is not displayed, predictive text is off.
Just to spice things up, Samsung's idiotic software designers made it so that depending on the situation you're inputting text, the order that things cycle through is different, so you can't just press it a certain number of times to turn it off, you have to pay attention to the icon in the top right.
Nov 26, 2007 | Samsung SGH-D900 Cellular Phone
Canon P1-DHV Calculator Logo
73 people viewed this question
old marine
old marine
