Question about Linksys Wireless-G WRT54G Router
I HAVE A WRT54G. I AM DROPPING MY WILDBLUE SATELLITE INTERNET SERVICE BECAUSE MY DIAUP IS FASTER AND MUCH CHEAPER. I WANT TO RUN THE NEW PHONE LINE TO A PC WHICH HAS A PHONE MODEM AND AN ETHERNET PORT. CAN I CONNECT MY WRT54G TO THIS PC WHICH HAS DIALUP AND BE ABLE TO USE THE INTERNET OVER MY WIRELESS ROUTER'S SIGNAL WITH THE OTHER COMPUTERS I NOW USE FOR THE INTERNET?
  • 3 Answers
The answer that he gave you is not accurate. In fact you can use your wireless over dial-up. This however takes a little work. You will need to setup internet connection sharing on your desktop with the modem. If you can get the sharing working, then you can use your ethernet card on your PC to transfer the internet back to your wireless router.
This will work, it has been a few years since I have done it, but I used it this way for several years.
Posted on Feb 17, 2010
    Guru:
  • 194 Answers
No. Wireless routers are only for use with Cable or DSL internet connections.
Good Luck,
NOLA Tech
Posted on Feb 01, 2010
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
Jun 02, 2012 | D-Link DSL-2640R Wireless G ADSL2 Modem...
Went from wildblue internet service to dsl and need to know how reconfigure linksey router
Wildblue is DSL Internet service provider.
You can change the Internet connection settings of Linksys E3000 manually.
Or you can simply reset the router and reconfigure it by running the CD.
See How to setup Linksys E3000
Oct 17, 2011 | Linksys E3000 Wireless Router
We get our internet service through Wildblue satellite. A few months ago we installed a router so that two computers could get online. A month ago our upload usage went WAY above our contracted amount. ...
ring your ISP internet service provider and ask them to provide you with the user name and password that you provided to get the internet
you might have to check your windows firewall settings this may vary on the operating system you are using
click start control panel system and security windows firewall you can block persons not on the list you provide also
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer also select users you will see who is using your computer
hope this helps
Jan 07, 2011 | Zonet ZSR1124WE Router
I have new direct tv installation. now my dsl keeps dropping out. i unplug the direct tv box and everything is ok?
It sounds like they have given you the base DSL service with the minimal speed. If they did, it won't be enough to run two things at one time on the same dsl line. Call AT&T and check your speed or service that was installed and ask if it is enough to run to computers on the same line at once.
Also make sure that there is no filter on your dsl line that goes to your computer.
Here is another tip; the longer the phone line from the wall to your computer, the slower the dsl service. Longer cords slow down your internet.
Nov 12, 2010 | AT&T High Speed DSL Modem
I have Wildblue internet service for my desktop..Got a new Toshiba laptop and can't get it connected to my internet.
FIrst of all is it wireless or wired connection?
if it is wireless then you have to run the wireless asstn from vista or need to contact the ISP to setup the account .
Aug 15, 2009 | Computers & Internet
Wireless router not communicating with computer
Dont run the CD. Connect the Wildblue to your router via the INTERNET PORT then your computer to ports 1 2 3 or 4. Turn off the router wait 10 seconds then turn it back on and restart your computer. you should be online. you dont need to install the router using the CD.
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
At&t usbconnect mercury
It is remotely possible but will be very complicated. You will have to leave the computer with the Mercury powered up all the time and use internet connection sharing to provide access to the other computers. But also you will need to reconfigure your router as a dumb switch since your PC will now be the DHCP server. In short it's not easy and not practical - but it is possible.
Dec 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
117 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
