Question about Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Hi-
We have a Kenmore 23.1cf chest freezer model #10233 that is not cooling below 14 degrees F. Any ideas?
Thanks,
Max G.
  • 3 more comments
  • infantrynco Feb 19, 2008
    Thanks for the quick reply. The compressor runs constantly, it does not shut off. I'll go outside here in a minute and pop the panel to look at the condenser coil.
    Thanks,
    Max
    Well, I removed the one panel and saw nothing but a compressor. There were no other panels that I saw. The compressor looked ok, no ice around it, but was unable to see any of the coils.
  • Anonymous Mar 20, 2014
    Have switched off, cleaned out and left off for couple of days, but on switch on it's still not cooling.
  • Anonymous Mar 23, 2014
    My Wood's chest freezer is set at the coldest, but it measures only 15 degrees
  • Anonymous Mar 24, 2014
    what does it mean for the red light beside Hi Temp mean on my Kenmore Freezer
    Sergeant:
  • 288 Answers
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • Rob Luna
    Rob Luna Feb 19, 2008
    O.k., the coil is inside the walls. It is used to keep the door warm and freezing on the gasket. I would look for the defrost control and check it. If for some reason ice has built up on the evaporator coil because of it not defrosting, it will give these symptoms.
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Mar 27, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
Kenmore Deep Chest Freezer
Correct temperature for residential freezer for food is zero degrees Fahrenheit
Jun 07, 2009 | Kenmore Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351 Logo
978 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
