Question about Kenmore Washing Machines
Clothes are still very wet when cycle completes.
When cycle completes the clothes are still very water logged. I need to run with the extended spin enabled and often re-run the drain/ extended spin when the load completes.
  • bryan_whyte Feb 01, 2010
    Sorry for the confusion, but this is a washing machine issue not the dryer.
    No, the clothes don't smell. I spoke to a couple of appliance repair men who wouldn't travel to my location and they gave me a couple things to try.
    1. Clear the clean-out for the water pump. Apparently this will require removing a portion of the front of the unit. Hopefully there is a simple service opening for this and I don't have to take the whole front panel off. This is pretty much what you are suggesting (a clog somewhere), so I'll check the drain line 1st.
    2. Make sure there is an air gap between the water outlet hose and the water level in the exhaust pipe. I guess he thought it might be frozen at some point which would raise the water level and cause a backup. I doubt this is the issue, because I think water would end up splattering all over the basement, but I'll check it anyway.
    My understanding now is that the drum would never get up to full speed if the water is not escaping fast enough. Apparently the unit will detect this weight and not speed up if the load is too heavy. I never would have thought of that.
    I'm going check what you recommended and the others and will post what I find. I was also thinking if I ran a load with just a single item in it, there shouldn't be a problem getting up to full speed because the load would be so light. Then I could see if the spin cycle ever gets up to full speed. That way I would know if there was an issue with the motor or a belt or something. Does that make sense?
  • 3 Answers
Clean the exhaut tube from the dryer to the ouside of your home
Posted on Feb 01, 2010
  • Jason Varan Feb 01, 2010
    my bad, only read what i wanted too.
    Sound to me like a drain line is backing up. Do the cloths smell bad too?
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Won't spin out clothes after replacing belt
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 03, 2009 | Crosley Washing Machines
Clothes were still very wet when cycle completed
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 14, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes are still water logged after cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
From Repairclinic
Oct 24, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
76 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
