Question about Ovens
Electric surge turned off the clock,oven but the stove top works
Whirlpool stove gr458LXMQ clock and oven dont work nor does the main control board lite up but all of the elements on the stove top work thanx johnny
  • leta2411 Mar 14, 2009
    My whirlpool oven wont come on. The stove top works and so does the clock.
  • Anonymous Mar 17, 2014
    oven clock not working after power surge
    Sniper:
  • 65 Answers
Do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
Posted on Feb 19, 2008
    Sergeant:
  • 288 Answers
The clock and display are leds, right. If you can remove the panel where the board is and gain access to the back of it, look for a fuse, similar to a car fuse. The elements are controlled by manual independent switches, that's why they are working. If there is no fuse, or its still good, look for a burnt wire of some sort back there, as you said a power surge went through it.
Oven stopped working after big power surge. stove still works but oven will not turn on and nor does digital clock
Both the oven and the clock are controled by the main board. The power surge probably destroyed the main board.
Jan 31, 2011 | Kenmore Ovens
Oven not working after a power outage. Stove top DOES work.
HI, The power surge has, essentially, destroyed your main control boards circuitry. This will happen during a power surge. Most oven control board are not protected from this type of potential damage. To confirm, simply unplug your unit for 5 minutes. Once the five minute reset has passed, simply re- introduce power to the unit, and observe. If you experience the same issues after the five minutes reset, this will confirm the damage to the control board.
It must be replaced if the damage persist after the reset.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Power went out. Back on now, monitor won't show on range. Can't set clock, so my stove won't work now. Any suggestions?
HI, you will need to replace the EOC/clock. the power surge has fried the chip set. Replace the control board.
Jun 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
315 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
