Question about HP Pavilion s7310n (EN996AA) PC Desktop
S7310n disassemble - HP Pavilion s7310n (EN996AA) PC Desktop
  • HP Master
  • 5,660 Answers
This is HP Support, and the download page for the Upgrading and Servicing Guide,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1156509&
On this page scroll down to - Upgrading and Serving Guide, and left-click on it.
(Second file listed)
This is a PDF file download. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the Upgrading and Servicing Guide, file name, you will Not see anything happening for up to 30 seconds, or so.
Be patient, as the file is downloading in the background.
The Upgrading and Servicing Guide tells you, and shows you, how to open the computer case. (Page 7)
Barring that you are not able to download this PDF file, I will attempt to tell you how to open the computer case. (If you are using a Dial Up network connection, you may be as old as me, before the file downloads)
1) Computer off unplug the power cable FROM the surge protector. (Not shouting)
THEN unplug the power cable from the back of the computer. (Power Supply)
Now unplug all cables connected to the computer.
2) Lay the computer on a towel on top of a table. Keeps the table, and the computer from being scratched.
Lay the computer on it's Right side. (Computer facing you, the right side is to the right. Hey, don't laugh, lol!)
Loosen and remove the three computer cover screws, on the back of the computer's case.
The computer cover that removes is an L shape. It comes down the Left side from the top, and wraps under the bottom.
Looking at the Top/Back of the computer, there is a screw to remove on the Top, of the Left side of the computer case. (Top/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Left side.
(Bottom/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Right side.
(Bottom/Right side corner)
After these three screws are removed, the Left side of the computer cover is slid back about 1/2 inch, (1.25cm), and lifted straight up.
BEFORE you reach inside! (Not shouting)
Your body carries STATIC electricity.
Static can fry out, (Short Circuit), the hardware components inside the computer.
TOUCH the metal frame of the open computer case, to relieve your body of Static electricity.
If you get up, walk away, then return, Touch the metal frame again.
Now, do you wish to disassemble this desktop computer completely, or just remove, and replace a few hardware components?
The above Upgrading and Serving Guide from HP Support tells you, and shows you,
1) How to remove, and replace the computer cover
2) How to remove, and replace Ram Memory
3) How to remove, and replace an optical drive.
(CD/DVD Drive)
4) How to remove, and replace a PCI card, that is in a white PCI expansion slot, on the motherboard.
5) How to remove, and replace the CMOS battery
6) How to remove, and replace a Harddrive
Should you need further disassembly guidance, let me know in a comment.
Posted on Feb 04, 2010
Trying to install a Sony 5280S-CB-PLUS
Did you connect the sata power cable as well
Mar 19, 2014 | HP Pavilion s7310n (EN996AA) PC Desktop
Does my hp pavillon s7310n slimline PC have wireless internet capabilities
Not built in, but you can pick up a USB adapter such as this one for cheap: moz-screenshot-1.pnghttp://www.walmart.com/ip/CNet-CQU-906-Wireless-N-PicoUSB-Dongle/15571889?sourceid=1500000000000003142050&ci_src=14110944&ci_sku=15571889moz-screenshot.png
Mar 01, 2011 | HP Pavilion s7310n (EN996AA) PC Desktop
HP Pavilion s7310n Slimline Desktop PC | how to change the power supply
This is an easy one, Purchase a new suitable PSU, probably from Dell, You will find a set of 4 screws at rear of machine, in line with PSU, undo these 4 screws. Unplug the plugs from all the connections, MotherBoard, DVD, Hard Drive etc etc. Then simply do the reverse procedure.. carefully reassemble..
Jan 27, 2010 | HP Pavilion s7310n (EN996AA) PC Desktop
My HP Pavilion s7310n was running and the monitor was shut off. When I turned the monitor back on I realized that the pc was off. Whenever I try to start the pc, the light on the front and the one on the...
If no PC start at all, ensure ALL power leads are securely plugged in to pC and wall socket. If still no go, try another power supply cable. If still no go then likely to be power supply.
Dec 21, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
I cant find the Ethernet drive for hp pavilion slimline s7310n can some one help me plz
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.hp.com/#Support
Nov 19, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
How do you fix an hp pvilion s7310n slimline pc burner
Good day sir, we dont usually repair a CD/DVD burner, we returm them to the supplier if they are on warranty, if not we buy a new CD/DVD burner, its much cheaper than to have it serviced.
Nov 12, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
HP Slimline s7310n...I had to do a new install of XP home as someone messed up an install of Vista...I cannot get the onboard ethernet to work and I have been unable to locate any drivers. I have went...
Open up device manager> double click on the unknown device> go to the details tab> in the drop down choose hardware id> google the alpha numeric code on the first row before the & symbol (ex- PCI\VEN_14E4)
That will give you the make of the ethernet adapter you have on the pc. Once you have it installed you can patch up the wireless as it works on the network adaptor base which generates the ip address.
Hit me again if this dosent do the trick.
Feb 18, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
Pavillion a305 w does not read DVD+R
try to update the firmware - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-54758-1&lc=en&dlc=en&cc=us&product=362754&os=228&lang=en
Dec 22, 2008 | HP Pavilion s7310n (EN996AA) PC Desktop
Cable to DVD came loose. Odd Connector
take note on the cables twist style just follow its twist.
Sep 16, 2007 | HP Pavilion s7310n (EN996AA) PC Desktop
HP Pavilion s7310n (EN996AA) PC Desktop Logo
277 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
