Question about Proscan PS32500 32" TV
PS32500 32" TV Problem
My TV makes a hissing noise which gets louder when I turn up the volume. I can't hear any audio whatsoever. The picture is fine.
    Novelist:
    Champion:
  • 236 Answers
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Posted on Feb 19, 2008
Hissing noise... louder as i turn up volume
Probably you should contact Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 16, 2015 | Philips TV Tuner Video Capture PCI Card -...
Mic not working on toshiba a665 laptop; hisses
Get rid of all possible noise in your recording space. Pick the least noisy area to record in. Turn off any fans, heaters, air conditioners and other nonessential devices. Even an extra laptop or idle gaming console makes noise, so if you're not using it, shut it off. Close the doors and shut the windows. Place your microphone away from any remaining noise sources, including power sources. Don't record next to a window, even if it's closed. Remember that your computer makes noise, too. Even sounds your ear can't hear will become noticeable once you amplify your recording. Finally, turn off any cellphones. GSM buzz can be picked up in your recording, so do not set the phone to vibrate. Turn it completely off. Get as close to the mic as possible. Positioning for tonality and comfort has to be taken into consideration, but beyond that you simply want to get as close as you can. The closer the microphone is to the audio source, the less background noise will show up in the recording. Turning up your source will accomplish a similar effect. Simply speak louder, or if you're recording an electric instrument, turn up the volume. If your levels start clipping, bring the volume down on the mixer. Tweak the EQ. After your audio is recorded, you can often eliminate noticeable buzz or hiss using the equalizer. If your mixer has equalizer presets, try playing with those before you start recording to see what bands you can turn down to diminish noise. If you're mixing digitally, you can record the audio straight in without any EQ and apply one during the editing process. Finding the right equalizer band to mix down is often a process of trial and error. If it's a hissing sound, it's going to be in the higher spectrum. If it's a buzzing sound, it's probably coming from the mid to lower spectrum. A graphic equalizer is a great mechanism to form a valley in the EQ and move it around until the noise is reduced. Use a speech enhancer plugin. Any good mixing program has one; even something as simple as Apple's GarageBand can do the trick. Or, try searching the Internet for a third-party plugin. The speech enhancer will let you apply some quick tone settings to make a speaking voice sound more professional. More importantly, it will give you the option to dial back the more quiet sounds in a recording. This will help isolate the vocal and push everything out. While this type of plug-in is meant for spoken audio, it can be used -- with mixed results -- on any kind of audio. Know your noise gate. The noise gate is your key to absolutely silent pauses and crystal clean audio. The gate takes out all noises under a certain level and turns them down however much you tell it to. If you find that your desirable audio never gets any quieter than -20dB, you can tell your noise gate to turn the recording down any time audio is not exceeding -25dB. You can even tell it how much to turn it down: all the way for a clean recording, or maybe just a little to allow some natural hiss in. The noise gate appears easy enough on the outside, but can be a little complicated to master. If your settings are too high, you will clip out parts of your recording, making it obnoxiously unlistenable
Feb 22, 2013 | Toshiba Computers & Internet
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
I have a ws-65511, it's been in storage for about 2 years. The picture is working fine but there is no sound. Digital cable box in hooked up properly with audio cables and Pr Pb video cables. Any ideas?
Here is somethings you can do/try.
Turn on tv and make note of any blink sequence on the power LED.
Verify you have no sound on any input.
Turn volume up on tv and determine if you hear any noise whatsoever coming from the speakers, in terms of hiss, hum, faint audio.
If you do here some sound, this points back toward your connection points where rust, or spiderwebs may be preventing good contact with the audio cables.
Depend on how you stored it, you could have had mice get into the tv and chew the wiring. Take the back cover off and inspect all the connections. Follow the wires coming from the speakers to where they plug into the board. Make sure the wires are not damaged
Look at the capacitors on the board and make note of any capacitors that have a buldge to them or the tops are rounded over. This is an indication they are bad.
Feb 20, 2011 | Mitsubishi Televison & Video
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Sanyo 24inch TV
Sounds like you have a bad speaker,or at the most the audio amp needs changing. Get old speaker out of another tv or stereo.
Oct 04, 2007 | Televison & Video
Proscan PS32500 32" TV Logo
137 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
