The system and transmit lights are off, what do i
The system and transmit lights are off. but the transmit lights blink occasionally. I have also tried to enter the modem's home page via 192.168.0.1 but can no longer do but used to be the way i enter it before. what do i do?
    Problem Solver:
  • 9 Answers
Couple of things to try:
1) Disconnect the WAN connection and turn off the modem. Connect your crossover cable to your computer directly, if your system is receiving an IP address from the modem then you know the device's internal structure is intact. Try to bring the administration window now, if you can get in try to reset the device from the administration calls. This will mean you will have to input the settings again but hopefully should work.
2) As with the previous instructions but download a copy of the firmware for the device from the manufacturers website (obviously from another internet connection) and use the facility to run the update. This will set the modem back to manufacturers specs again and hopefully get back to cruising the net again.
3) If the previous 2 methods didn't work then time to get a new modem!
Best of Luck,
AusMounty
Posted on Feb 03, 2010
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
Jan 26, 2016 | Panasonic Heating & Cooling
Tip
How to Troubleshoot Blinking Lights on a PS3 Controller
Video Guide to this tip is HERE Accessible>>
The controller for the PlayStation 3 is unique to any other previous PlayStation controller in that it is wireless. The controller is not physically plugged into the system, which means that you can still use it from any point in your room and you don't have to be a specific distance away from the PS3. Occasionally the controller will run into problems, which are often displayed to the user as a series of blinking lights on the controller itself.
Step 1 Move closer to the system. If you get too far away from the PlayStation 3, the controller will not be able to transmit its signal to the system. This will cause the lights to blink and the controller to become unresponsive.
  • Step 2 Recharge the controller. As the PS3 controller is wireless, it operates on an internal battery. If the battery becomes too low, the lights will start to blink, alerting the user that it needs to be plugged into the system to charge. Plug the controller into the system and charge it fully before attempting to use it again.
  • Step 3 Turn the controller on and off. If the lights start to blink and you can't determine the reason, turn the controller off and then back on again. This will clear its internal memory, essentially resetting it. When the controller comes back on it will operate as normal, without blinking lights.
  • Video Guide to this tip is HERE Accessible>>
    GAMES PORTAL ARCADE ON http://playstationportal.blogspot.com/
    on May 29, 2010 | GPS
    I have a red signal light that keeps blinking in gp328 any ideas?
    A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
    Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
    Best regards.
    Sep 17, 2014 | Radio Communications
    Rpn 479v p x
    Here is something you can try to see if it is transmitting out from the handset
    Put your new battery in and push and hold down the button and look at the transmitter LED through a digital camera, a phone camera works fine. you don't need to take a picture, just look at the LED trough the camera.
    If its transmitting you will see the LED light up.
    Test this on your TV remote as you know this one is working so you know what to look out for.
    If its not transmitting you know its the handset at fault, if it is transmitting its probably the recever.
    Hope this helps a bit.
    Feb 09, 2014 | Vehicle Parts & Accessories
    Gme gx300 transmitting problem
    do you have a mike filter on your system
    Jul 19, 2013 | Boating
    My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
    Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
    When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
    If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
    If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
    If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
    So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
    I hope this helps.
    Randy
    Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
    Ethernet light blinks continuously on my bigpond wireless. Does that mean there is a problem?
    A constant blinking Ethernet activity light indicates that the computer is transmitting and/or receiving information from the internet or other network devices. It's nothing to worry about. The light may be constant only when we are setting up the modem.
    Regards,
    Shrey
    Jun 01, 2011 | 2wire (1000-000057-000) Modem
    Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
    Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
    Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
    The remotes for my system do not operate when I press the lock or unlock or remote start buttons. Is there a way that I can reprogram the two remotes to work with my remote start sytem. It is the python...
    The "pair" the remote with your system:
    1.PRESS AND HOLD the f button on the remote UNTIL the transmit LED lights solid (approximately 10 seconds)
    2.PRESS AND HOLD the remote start button (circle arrow) UNTIL the LED blinks 3 times and the amber transmit LED lights up. Your remote is now ready to pair.
    3.. Turn the key to the on position
    4.Within 5 seconds PRESS AND RELEASE the control button on the antenna.
    5. Within 5 seconds PRESS AND HOLD the control button. The status LED will flash one time and the siren will chirp to confirm that the system is ready for remote pairing.
    6. Press lock button on remote. System will respond with chirp toconfirm pairing.
    Oct 28, 2010 | 1401 Remote Start/Keyless Entry System
    T8500 blinks off and back on often when transmitting
    It takes more energy to transmit than to receive. It is possible you have an old or defective battery pack, a bad connection to the battery, or your PTT button is not working properly. On this unit, the internal PTT button can begin to be bent further in from repeated use, or pressing too firmly.
    As far as a more durable/reliable radio, you might want to look at radios in the business division such as the Motorola CP110, BPR40 or the CP150. These business level radios are built to work a 40+ hour work week, and are much more reliable than the consumer division products, which are intended for occasional usage.
    Jan 17, 2009 | Motorola Talkabout T5720 (7 Channels)...
    Computers & Internet Logo
    53 people viewed this question
    David Payne
    David Payne
