For the HL-2140 Brother printer, the red error
The red error light remains on when trying to print to our HL-2140 Brother printer, and will not print documents in que. We have turned both computer and printer on/off, checked all connections & checked for paper jams, opening and closing firmly all trays, etc. We still have same problem. Can you help? Andrea
  • kustay Feb 02, 2010
    RE red error light staying on when using the Brother HL-2140:
    After a couple of hours reviewing the on-line manual, we realized that what we were printing, a full sheet of labels on plain paper only (prior to printing on a sheet of Avery labels) had automatically triggered the "manual feed" on the printer, thus the red light. The red light would not go off no matter what other adjustments were made. We had to utilize the manual feed option before we could get the red light to turn off. The steps for using the manual feed require one to adjust 3 different things on the printer first before feeding anything into the manual feed slot, but once the routine is carried through the first time it is much easier the next. The on-line manual also listed the other reasons offered by komguy in his post above, for which we are very appreciative! We started with the least expensive/time consuming first with plans to "work our way up" the list of suggestions. Thanks to komguy for sharing the tips! We think this is a good printer, especially for the price, just a tad bit fussy at times due to various adjustments required for different scenarios! Thanks from 'Printing again'
  • idling
    idling Oct 25, 2012
    kustay is totally correct! did the manual feed and it got fixed immediately!
    President:
  • 2,306 Answers
Too many things can cause that, you remove the drum and run the blue tab back and forth to clean the corona about 20 times, the fuser may not be heating and you need a new fuser, Feel for heat in the back door or at the exit, If the drum is used up you open the front door and press go until the lights flash to reset. Make sure the paper tray is fully inserted, this one is picky. You may need a shop to diagnose.
Posted on Feb 01, 2010
Testimonial: "Thank you komguy, I posted the solution to the problem we were having, and we appreciate your willingness and time to share your expertise! "
Why brother hl 2140 error light
The error light indicates something is wrong with the machine. The error light in combination with another light indicated that the problem lies with that item.
If there is an issue with a job not being able to be printed you can press the go button to allow it to continue (Normally happens if you send a job to the printer using paper other than what the printer has in it)
Aug 29, 2014 | Brother HL 2140 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
I need free support to empty memory of brother HL-2140 printer
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
Dec 27, 2012 | Brother HL 2140 Laser Printer
WILL NOT PRINT, there is paper and toner, the power is on, there are no error lights on or anything! what do i do totroubleshoot?
Most of the time the printer refuse to print if the print memory is full, if this is the case then, press the Go button to print the remaining data in the printer memory. Cancel the print job if you want to delete the remaining data in the printer memory.
If the above solution doesn't work then the best alternate is to restart the printer and computer. Restarting help to overcome any minor problems. If restarting doesn't help, I suggest you to call In USA: 1-877-BROTHER (1-877-276-8437) In Canada: 1-877-BROTHER
or logon to www.solutions.brother.com
Feb 05, 2011 | Brother HL 2140 Laser Printer
Why can't i print, the red light next to error is blinking
have you tried re-installing the driver of the printer?
May 19, 2010 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 won't print from Firefox (or IE)
am not very sure but i think u should try go to printers and faxes through control panel open it and right click on your printer and select print on line
Jul 17, 2009 | Brother HL 2140 Laser Printer
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Dec 19, 2008 | Brother HL 2140 Laser Printer
1,029 people viewed this question
jasbo
jasbo
