Question about Fujitsu Plasmavision PDS-4209 42 in. Television
Fujitsu Plasmavision pds-4208 Display randomly
Hey everyone =D any help would be greatly appreciated!
this is my problem...
i have this plasmavision it has been working fine since i got it, now all of a sudden the picture will just disappear, as its only a display unit and I'm running my audio thru my home cinema system.
its an intermittent fault but its been progressively getting worse, sometimes a sudden display change will cause it to stop working, a total display loss with no osd... however green light continues and the psu still carries on operating with fans going... until a couple of minutes when it will shut itself down and display an orange light for no input signal.
Ive had the psu out and tested all the connections as i have the service manual but no schematics. when the unit is fully operational all output voltages are correct but a few which maybe a volt lower or higher than stated.
however when the unit stops displaying a picture, the x and y sustain outputs drops its tension... only one connection does this on the CN49 on the Ve pins for both x and y sustains the tension drops from nominal 16v to 4.2v
i have removed the sustain connectors to power up the psu and funny enough... without the sustain boards connected the pin has only a 0.2v output
this is really confusing me now. Its a bit of a bummer too as i have no schematics to follow *puh*
am i right in thinking this is solely a psu problem?... or maybe a faulty digital board?.. seeing that the display shuts itself off due to no signal? or could it be a faulty sustain board?
does anyone know whats going on or had this problem before? kindest regards to all... Jay
jaydeeks(at)hotmail.co.uk
Tip
Drivers for Fujitsu Plasmavision 42" Display
At http://www.plasmavision.com/tech_faq.htm the following answer is not exactly true:
Q: I'm running Windows XP on my Plasmavision display. Can you please send
me, or tell me where I can download, the video drivers for this model?
A: Video drivers are part of the video card installed in your computer, rather than the monitor showing the computer's images. Please check with your video card manufacturer. All Fujitsu displays are Plug-N-Play devices, so there are no drivers available.
For the PDS4203-WH circa 1999, there was an optional video card based on an S-3 ViRGE chipset that allowed you to connect your computer to the display and get the best use of the 852 (H) x 480 (V) display. Without this, almost all video cards fail to display fonts so that they are perfectly legible, which can be quite problematic, lol. Hopefully, this problem was resolved in later models, and they truly are Plug n Play.
Back in the day, this was a great monitor for playing video games. Outcast, from Infogrames, was gorgeous.
on Sep 20, 2010 | Fujitsu Plasmavision 42" TV
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
Fujitsu Plasmavision 42 42'' TV 4209 picture last for 5 minunets then black ??? Power supply ???
No not power supply, it's the X and Y sustain boards. These boards have to be replaced as a pair.
Contact Fujitsu for a repair of this unit.
Feb 16, 2010 | Fujitsu Plasmavision PDS-4209 42 in....
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Turns off after awhile
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Apr 12, 2008 | Fujitsu Plasmavision PDS-4214 42 in....
Fujitsu Plasmavision PDS-4209 42 in. Television Logo
53 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
