Question about Dell Dimension XPS 400 PC Desktop
Its a Dell XPS 400
When I start the computer and it runs through the start up it does not read the keyboard, will not let me hit the F2 or F12, or get the reinstallation CD to boot, and ends with
Keyboard failure
Floppy diskatte failure
Strike F1 to continue, F2 to run the set up utility
  • 1 more comment
  • SmokerJ Feb 19, 2008
    Sorry, I need to be alittle bit more specific. The Keyboard is good it works great on my Tower unit. Just not on the One I'm trying to fix. I've tried to disconnect all connectors(one at a time) checking for loose or broken ones. I'm about to pull my HD and switch it with the one in the bad tower. But fearful of messing that one up too. Thanks for the prompt reply "Mr. Fixit"
  • infortm Jan 11, 2009
    Same as poster
  • Anonymous Mar 28, 2014
    it loads to page of F2 or F12 for start up settings but underneath it says keyboard failure, so I can't do any of the keyboard commands.
Go into thye BIOS and turn off USB bootable device. The error is because the computer is trying to use the keyboadr to boot. At least it solved my problem.
Posted on Jan 17, 2009
  • 33 Answers
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Posted on Feb 19, 2008
Xps 400, no keyboard in dos
Dear Sir:
I am recomending to go www. and go to troubleshooting section for diagnose the computer, the problem I see is driver some missing. You must need to reinstall. By that reason Run the Diagnose from Dell .
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 12, 2012 | Dell Dimension XPS 400 PC Desktop
Please restart your machine and keep tapping F12 key from the keyboard
It will display a menu with options
Press enter on DIAGNOSTICS option
Let's confirm if the hard-drive is not gone bad
It will confirm if all tests are passed, you don't necessarily need to run the extended memory tests
Or you can also check in F2 menu (BIOS menu) during reboot
if the Hard-drive/SSD is detected on your XPS 13 notebook
Try to load BIOS defaults too.
Please reply back with the results.
Dec 27, 2017 | Dell Studio XPS 13 Laptop Computer (Intel...
DELL portable XPS M1530 Error Code 0146 Msg = Error Code 2000-0146
you have a missing start up driver try to trouble shoot run windows on f12 promp f2 then asked to run windows run windows.
Feb 04, 2011 | Dell XPS M1530 Notebook
I have a dell inspiron 1564. To use the f1-f12 functions require me to first hit the FN button. How do I reverse this so that i can use f1-f12 by hitting them directly and have the current commands...
You can change it so you don't have to use the FN key by going into the settings while you computer is booting.
Reboot your computer
Keep hitting F2 until a greay and blue settings screen comes up
Choose the Advanced menu
Use your arrow keys to go down and select 'Function Key Behavior'
Hit enter
Select 'Function Key First'
Hit enter
Choose to Save and Exit (usually F10)
Should fix it up.
Shaun Thomson
Billy Goat Karaoke
Aug 30, 2010 | Dell 0Y3740 Keyboard
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 20, 2010 | Dell Dimension XPS 400 PC Desktop
How to reset admin password in bios on dell xps 400. Or is there a default or backdoor password for dells?
no default password is there..if you want to enter the bios..start the desktop..hit either F2 or F12 and it will open up the bios for you. you shld be able to find a option of password in that..
Feb 23, 2010 | Dell Dimension XPS PC Desktop
I have the same problem with my XPS One
Ugh-ogh... are you such an advanced user to re-flash BIOS?
Mar 23, 2017 | Dell Inspiron XPS M2010 Notebook
to go to safe mode press F8 just before windows starts. this works on all versons of windows.
Jul 23, 2008 | Dell XPS 200 PC Desktop
My Dell xps 600 won't startup
have you check the hardware of your computer? try to change the memory of your computer. and check the cables of your keyboard and mouse.. if there is any problem again try to contact me. thanks!
May 28, 2008 | Dell XPS™ 600 PC Desktop
Dell Dimension XPS 400 PC Desktop Logo
741 people viewed this question
Alun Cox
