Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Briggs/stratton how do I get cover off of pull rope. looks like it's rivited on
    Problem Solver:
  • 15 Answers
You have to drill the rivets out. If you're changing\rewinding the rope, you have to do it from the backside.Respringing it you'll have to change the whole thing, which is easier anyway. your local briggs dealer can order one for you, and after you drill the rivets out, the new one will come with little bolts and nuts.
Posted on Feb 10, 2010
5hp briggs and Stratton will fire with pull rope cover off but not with it on
Hi Danny, Seems like a positive wire is exposed and earthing out with the cover on.... Have a good look around as you put the cover on, I hope this helps.......CHEERS..
Apr 28, 2016 | Garden
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
How do you start a biggs stratton 450 series rotorvator
Usually the 450 series only a recoil starter....a pull rope to start it. Meaning you have to pull the starter rope to start it.
Apr 28, 2014 | Briggs & Stratton Garden
How to replace the broken pull rope
The link below will go over the process of replacing the rope on a briggs mower (process will be similar to your engine for basic idea)
http://www.youtube.com/watch?v=iczCZaRiR0Q
If your starter is bolted to the fan cover it will be easy to remove the rewind and install the rope. If rewind is rivited to fan cover, pull off the fan cover or cut the rivets and then install new rivits (not enough space to use nut with bolt to hold rewind due to close proximity of flywheel). Post agan if you have other questions. Dont worry, easy repair.
Aug 11, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Have to change pull cord but rivits holding down cover am i to drill these out if so stupid design.
If this is a Briggs and stratton then you have to take the engine cover off which is held on by 4 bolts and replace rope. unless you have a rivet gun to replace the rivets you drill out
May 15, 2011 | Cub Cadet Garden
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 2500 craftsman power washer with a Briggs and Stratton engine. I used it about a month ago and it worked fine. Took it out yesterday and I could not pull the rope to get it started. I took out the...
It sounds like the pump is seized. Make sure any pressure has been released by pulling the trigger on the gun. Sometimes this will allow you pull the cord. If the pump is seized, a new pump would be in order.
Jun 15, 2010 | Briggs & Stratton Garden
Pull cord broken. After removing red hood and
You don't need to remove the rivets. There should be two metal tabs that bend over the nylon retractor, or it'll have a screw in the middle of the retractor pulley inside the cover. you bend those up a little, or remove the screw, remove the retractor, be careful, because that spring can be fun if it gets away from you, take the old rope out, put the retractor back in place, wind it back as far as you can, feed the rope in, tie the knot, and let it draw the rope in. Put everything back like you found it, and your pull rope if fixed.
Mar 11, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My neighbor just gave me a Troy Bilt 020207 power washer. It is 2450 PSI and 2 GPM. He snapped the pull cord rope. I looked at the pull cord cover and it seems to have 3 rivets holding it to the main...
sounds like a briggs engine, DONT remove the rivits, go down a little further and remove the 4 3/8 bolts that hold the blower housing on.Turn it upside down, prewinf the pulley in the direction that it turns when the rope is being pulled. When it stops turning because the spring is tight, let it unwind one turn and line up the hole in the pulley with the hole in the metal part where the rope comes in and slip the rope in, tie a not and melt the freyed end. Let the starter pull the rope in by itself.
Nov 15, 2009 | Briggs & Stratton Garden
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
175 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
