Question about Philips FTR-9964 Tuner/Receiver for Plasma
Philips plasma tv model #42pw996217
I have the screen, however I am missing the reciever box and the remote control for the philips plasma tv model number 42pw996217. Question how do I get a reciever box or an E-box that is suppoesly compatibale. I cannot turn on the plasma change channels, volume control or anything else.
I am dead in space.
Kevin C. Doggett
doggett_98@yahoo.com
718 792-1248
YOUR ASSISTANCE IS DESPERATLY NEEDED
    Problem Solver:
  • 3 Answers
Kevin I don"t know if you still have this problem? but if so I have a box and a remote. make a good offer and its yours.
R.Carter
469-337-4962
mrrcc2@yahoo.com
Posted on Nov 11, 2008
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
I have a 26" fluid plasma T.V. I did not recieve
If this is the remote that goes with this television, and this is not a universal remote or one for a different model it does not need to be programmed. There is often a button on the remote that adjusts the picture size. It may be wide, format, view mode, aspect, zoom, and etc. This option may also be in the menu if there is no specific button for this task. However there are reasons that the screen size will not adjust even when pressing the proper button.
Now if you are using a cable box or satellite tv receiver there may be a button on your cable or satellite remote that will adjust the picture size. It is usually hdzoom # on the cable remote and format or aspect on the satellite remote. Picture format may also be in the cable box or satellite tv receiver's menu options.
However if you are connecting with an over the air antenna or direct cable and you are watching a high definition program this sometimes happens. You will not be able to adjust the screen size. Also if you are using a cable box or satellite tv receiver and it is set at a higher resolution than what the television is designed to display then this will happen and there will be no way to adjust the picture size. The cable box or satellite tv receiver could also be connected to your television with a coaxial cable to the rf/tv input. If you are in that input rather than the av, component, or hdmi input then this can happen.
Apr 27, 2011 | Televison & Video
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
CAN'T TURN ON MY PHILIPS 42FD9925/01 SCREEN, ALWAYS IN STANDBAY
Did this solution work as I have the same model and same problem and I have ordered the remote from philips suppliers
Jun 20, 2009 | Philips 42FD9932 42 in. Plasma Television
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
I can't see my tv
You likely need to select channel three or four on the TV itself if you have any kind of box between you and the signal source (cable, antenna, satellite). Magnavox is a name owned previously by Philips and now by Funai. They may not have all the info from Magnavox and Philips but you could check their website to see if they have the instruction manual for download.
Look under 'Support'
Funai
Jan 20, 2009 | Philips E-Box FTR9965 DTV Receiver
My remote dont work
I have a Phillips Magnavox 5 device Universal Remote, model MRU3500 that may help.
JVC brand - including LCD, Plasma & Panal televisions Codes: 0607, 0204, 0321, 0508, 0617, 0326, 0993, 0802, 0108, 0308, 0715
Sep 03, 2008 | Philips 5-Device Universal Learning Remote...
Older sony tv kx-m270 1986 model, missing remote control
you need the sony avu-270 or another home theater
Feb 26, 2008 | Sony RM-EZ2 Remote Control
Open Questions:
Televison & Video Logo
202 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
