Question about ASUS Eee PC 701 Notebook
Connect tv to eeepc 701sd
I have eeepc 701sd and want to use my tv as monitor, ive turned both offf and connected 15 point vga, have switched both back on and very briefly windows flashed on tv screen then went off. have been given advise to use fn key and f5 (2 screens seperated by slash) but still nothing. am i doing it right and is there any order as to what to switch on first (pc or tv?) thanks
    Guru:
  • 689 Answers
Hold down the keys for a few seconds ,make sure you havent pressed Fn-F1 in error as this will put the eeepc into suspend/sleep mode
Posted on Sep 04, 2010
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How do i restore my eee pc 701sd
There should be windows XP restore DVD when you purchased it. Connecting your eeepc to a usb DVD rom and boot from the recovery DVD. It would automatically run the recovery process.
May 09, 2010 | ASUS Eee PC 701SD 8G Notebook
I have used 15 point vga to connect laptop to my tv so can use tv screen as a monitor, tv screen just stays blank. how do i switch to external monitor?
Look at your functions keys. most common is F3 but sometimes another key, it will have a little monitor on it, or two screens with a slash.
Press your function (fn) button and this key, it should toggle between Laptop monitor, External, both.
(this is assuming you want to clone your monitor, which is what you described).
Feb 01, 2010 | ASUS Eee PC 701 Notebook
I CANT GET MY E169 MODEM TO WORK ON A EEEPC 701SD
Now i need your trust on this one---i also have failed to get these dongles working--and some of them are £20 and some £49.99--if you as me my honest opinion i think people connected to this company (huawei)post this rubbish so you buy the modem and waste your money.
the standard eeepc doesnt recognise the dongle in its wizard set-up.your welcome to try some of the hamshack script line code which,if you look on the net you will find--me personally i wont be trying again
Dec 18, 2009 | ASUS Eee PC 701SD
Error 17 when booting up Asus Eeepc 701sd
You should try to repair your windows. Which OS you are using...
Aug 30, 2009 | ASUS Eee PC 701SD
Bluetooth fails to start on EeePC 701sd (Linux)
I don't think your EeePC 701sd has bluetooth.
Check the specifications of the various models:
http://event.asus.com/eeepc/comparison/eeepc_comparison.htm
You it really is important for you, you might buy nd install a bluetooth adapter that is supported by Linux (it seems most of them are). Check the Linux forums, though, for advice
Aug 03, 2009 | ASUS Eee PC 701SD
When i bought the computer i had no broblem connecting to the internet, now all of a sudden i cant connect.
Have you changed the configuration settings of your network?
And have you updated your system? There is an update that deals with the difficulty of Eeepc connecting to WPA protected networks.
Also, my experience tells me that although the Eeepc detects the networks easily, it doesn't always connect and it is prone to blockages, that force us to recconnect. So I set my definitions manually on my Eeepc and everything runs smoothlier.
Jul 18, 2009 | Asus Eee 701Sd Notebook
No wireless connection
I am assuming you're referring to the Asus Eee PC 701SD... if so, try the following:1. Check the hotspot to see what kind of IP address it is using [are they manually configured, or is there a DHCP server that assigns IP addresses] 2. Check your 701 and make sure its network connectivity conforms with the settings on the hotspot
Jun 18, 2009 | ASUS Eee PC 701SD
ASUS Eee PC 701 Notebook Logo
209 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
