Cannot get my planatronic headset to work Plugged
Cannot get my planatronic headset to work Plugged in both plugs into USB connector and then pluggedinto USB point on computer and when I do a Skype test I can't hear myself, help please. Do I keep my normal speakers on or do I switch them off before I plug in the headset
Thank you for gettingf back to me, but after spending all day checking wires and plugs I went away annoyed, a friend came I told them the problem and they just got hold of the head set plugged it in and it worked, don't ask me why.
Posted on Feb 02, 2010
The headphones don't work on my PC when plugged in to any of the USB ports they are very distorted and are very crackly.
Do you get a good sound from your PC using other headphone? Mean, are you sure you don't have a problem with your PC's audio card?
Jun 27, 2015 | Creative Labs ChatMax HS-720 Headset -...
Dynex headset does not shut off sound from desktop when plugged in usb port
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
Otherwise, I would recommend pursuing replacement options
Sep 13, 2012 | Dynex Mono USB Headset with...
Headphones usb not working
try uninstalling and then re-installing it.
Plug the USB connector into an available external
USB port on your computer or laptop. On most
computers, drivers install automatically and your
headset will be ready to use.
Note: On windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
If you can not hear audio on your headset, adjust some or all of the following settings:
• Plug the USB connector into an available USB port.
• Restart computer.
Jan 22, 2012 | Dynex Mono USB Headset with...
Has a USB connector that when I connect I can not use my Google Talk - what am I doing incorrectly? Best, Yvonne
try uninstalling and re-installing the headset. Plug the USB connector into an available external
For any audio issues:
• Restart computer.
Sep 24, 2011 | Dynex DX-840 Headset
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
My planatronics bluetooth headset and device only work sporadically. Soemtimes transmitting sound and sometimes not, sometimes picking up the handset when prompted and sometimes not. Any ideas?
hi. at one point i purchased a moto-700 and it had the same exact problem, when i pulled the mike down it would work for about 10 seconds than disconnect. i pulled mike in and out about 20 times and finally it kicked in and now its my favorite tooth,probably not a solution just sharing my experiance with ya. good luck.
Jan 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
Panasonic TG8222E
The Panasonic TG8222E is not a bluetooth capable device therefore it won't work with your Plantronics headset.
Have you checked underneath the base station for your remote access code?
May 22, 2008 | Lands Phones
Headset problem
Check the bottom of your phone. There is a connector down there, is there any greenish stuff (oxidation) on it ? If so, the connector has been exposed to water. Clean the connector as well as possible, it might have short-circuited the pins and the phone thinks it has the headset plugged in. You might have to take the phone completely apart and clean it from the inside. If theres no greenish stuff on/in the connector, you probably have to visit your local Service-Center for repairs.
May 30, 2007 | Nokia 6260 Handheld
 Grubhead
Grubhead
