Question about OKI MICROLINE 320 Turbo Matrix Printer
I have a I/F= BAD error on my printer what does this mean?
10.1001 supply memory error
Hi Dang,
A supply memory error can mean a couple of things. The first thing is that the supplies are not correctly seated/installed. Turn the printer off and reseat/install all of the supplies. Turn the printer back on and see if the error clears. It can also mean you are using compatible cartridges. If that is the case usually pressing the green "check mark" button will allow the printer to continue. It can also mean that one of your cartridges is bad or the sensor in the machine is bad (although this is rare).
In case Still Having Problem Then Follow Us For Hp Printer Problems For On :
HP Printer Support
Feb 06, 2014 | HP Laserjet Cp2025n Printer
Printer not taking paper and displaing fuser error
In my considerable experience with this printer, a fuser error almost exclusively means that the fuser is bad and will need to be replaced. Which error does the machine post?
Apr 04, 2011 | HP LaserJet 3600n Printer
Hi m getting HP3005dn MEM Test Error Replace DIMM appreciated for the solution to the above problem thanks
This error can mean one of two things.
1. if you have additional memory installed it is bad.
2. The formatter of the printer is bad.
Feb 16, 2011 | HP LaserJet P3005n Printer
Hi error code: Call service 6020:0053103 Can't
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Feb 14, 2011 | Kyocera FS-4000DN Laser Printer
Fuser error 50.9 came up when we turned the printer on what does that mean??
normally this error means you have a bad fuser assembly. These items are normally a customer replaceable part. If replacing the fuser assembly does not correct the error code you may have a bad power supply board.
Sep 30, 2010 | HP LaserJet 4700 Printer
What does it mean when it says cartlige error 1203 consult user guide
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 14, 2010 | Lexmark X7170 All-In-One InkJet Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
Error 1203
Yes this happens lots on Lexmarks
or
Oct 06, 2009 | Lexmark X4270 All-In-One InkJet Printer
What does error code SC387 mean on a dsc332 colour copier the machine giving off very bad fumes also
it means you have a calibration error in your yellow development. you probably need a new yellow dev unit or the clutch or gears that drive it are bad. it could be a bad motor also
Sep 23, 2009 | Gestetner Office Equipment & Supplies
Error message
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesnt work just call up their support number and check for replacement..
Note: Refilling carts may damage the contacts of the carts as well as the printer.
Jan 14, 2009 | Lexmark P4350 All-In-One InkJet Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
221 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
