My heater is not working reliably. With the setpoint above the room temp, it may come on right away, or not for 12 hours. Pilot/igniter is ok, and will sometimes start the furnace heat going, then shuts off. New digital Honeywell thermostat, worked fine until 3 weeks ago. Thermostat says Heat when it's trying to turn on the furnace, but often nothing. Sometimes when it's starting up a loud buzzing sound comes from the furnace, perhaps a relay oscillating.
  • 22 Answers
Could be an open or stuck limit switch, not really a good thing.
Posted on Feb 01, 2010
Have a new richmond water heater.there was no hotwater.i checked the water heater pilot was not lit.i relight it, it lite.turn to temp settings pilot went out.relit it againmade a explosion bom sound
the explosion was from a build up of gas that was not properly ignited by the pilot light or was leaking into the combustion box when there was no pilot light
there is a serious problem in the gas control system that needs urgent professional assistance to fix
you were lucky as it could have blown you out of the room
get in an experienced gas fitter as it is not a diy job
May 11, 2016 | Water Water Heaters
Y does my glw-warm heater keep shutting off
Is this an unvented heater? They have oxygen depletion sensors which shut off the heater to prevent burning up all the oxygen in the room. Heaters over 10,000 btu's should not be used in small rooms like bedrooms and bathrooms. Other causes could be a dirty pilot orifice. Turn off the unit (so pilot is off) and use a can of compressed air with attached straw, to blow out any dust from the pilot assembly. (Where the pilot flame comes out). This will allow the pilot to burn a strong blue color and keep the thermocouple heated properly. If it's a thermostatically controlled heater, make sure your thermostat bulb is cleaned off regularly. Dust will insulate the bulb from sensing the room temp and will not operate properly. Hope this helps.
Mar 25, 2015 | Heating & Cooling
Gas furnace not turning on pilot is lit Bryant
Look inside the burner area and see if there is a glow when the furnace is turned on/temp dial turned above room temp . If it has no glow then the igniter/control unit is bad; most likely the ignitor.
Jan 02, 2015 | Heating & Cooling
A.O. Smith ProMax Plus GVR 50 101 Safety Question
You need to inspect and clean the air intake located on bottom of unit. Get more fresh air to the water heater and see if problem continues.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Instructions for lighting the unit are located on front of water heater.
Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances.
Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
Aug 12, 2012 | Water Heaters
IHAVE REH 241 RINNAI HEATER THAT WAS GOING OUT AFTER A AN HOUR OR SO I CHANGED OVER THE OVER TEMP AND THERMOCOUPLE COMBINATION WORKED GREAT FOR ABOUT A WEEK NOW HAS SAME PROBLEM AGAIN
Hows the pilot flame looking, is it nice and blue. The pilot flame on some of these units has was called oxygen depletion safeguards. It's to shut the unit down if the oxygen level in the room gets low. In practice it means the pilot light has to be perfect. I always like to recommend getting these units serviced regularily.
Jul 01, 2010 | Heating & Cooling
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Feb 17, 2010 | Raypak Versa 130,000 Btu Above Ground...
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
