Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Cap locks my cap locks are on when i go to turn on my laptop and my screen is black the plug in is showing blue and power is yellow amber. its like this problem won't open my screen. the other lights on are under the f10 and f11.
    Sergeant:
    Champion:
  • 310 Answers
I do no exactly you can try this. First check your computer with safe mode. Check it in that safe mode again its shows the same problem means check your display device or card
Posted on Feb 19, 2008
Turn on power.caps lock blinking light,f10 button is amber,screen is black,help
first remove ram and clean gold track with pencile rubber then try to boot
Jun 12, 2014 | Compaq Presario Notebook
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
Any solutions to my notebook problems
The first thing to always try is resetting your PC. With a laptop, you must unplug it and remove the battery. While the laptop is unplugged and the battery removed, hold down the power button for a minimum of 30 seconds. This will reset the PC. Plug it back in and see if it works now. Always try to reset the PC first, for many different problems.
May 31, 2014 | Compaq Presario Notebook
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Have dell inspirion1525. Screen is black. By holding down fn key and start key i get flashing lock with 9 and blue lock wih an A and blue lock with a down arrow. What do these mean?
Well the Flashing "lock with 9" is Num Lock, the "blue lock with an A" is Caps Lock, and the "blue lock with a down arrow" is Scroll Lock. Hope that answers that question.
Now for the screen being blank usually means there is an issue with either your LCD display or an issue with the laptops video card. Plug in an external monitor and boot up the laptop if you still get a blank screen then there is an issue with the laptop's video card. If you can see your screen on the external monitor then there is an issue with the connection of the LCD displayon your laptop. You can try ifxing it your sleve by opening up the laptop and making sure the connection is firm or you can take it somewhere to get it fixed.
Please rate if this helps
Mar 15, 2011 | Dell Vostro 1500 Notebook
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
May 03, 2010 | Computers & Internet
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
Dec 13, 2008 | Dell Inspiron 1525 Laptop Jet Black
R52 laptop screen stays blank
Try removing the battery and starting up just on power supply. May be a bad battery. If that doesn't work let me know.
Jun 06, 2008 | IBM ThinkPad R52 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
251 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
