Question about Microsoft Xbox 360 Controller
My xbox controllers are not connecting to my xbox how do I fix this problem?
  • 20 Answers
This might seem like a stupid question, but are you aware of the button on your Xbox that searches for controllers that are in range and on? It's a small button next to the Xbox power on/off button.
Also, once you click and hold this for a few seconds (you can release once the rings on the Xbox power on/off start to glow green) then you have to press and hold a button similar to the one on the Xbox, on your controller. Situated next to the LB button on your controller. Hope this was of some help, feel free to contact me if you are still having trouble.
Posted on Feb 02, 2010
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My Xbox controller will not connect to my console (Xbox 360 S). It was working fine and I connected it to a friends Xbox and used it, it worked normally. When I got home it would not connect to my Xbox. I...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
My xbox 360 controller will not connect to my xbox but it will connect to my friends xbox
See if any xbox controllers will connect to your 360. If you can't get any to connect to your xbox 360 then that means you have a bad controller board. If you can get other controllers to connect then that means you need to configure your xbox to accept that xbox controller.
Apr 28, 2010 | Microsoft Xbox 360 Controller
Keeps saying connect controller,this is a new xbox elite
the problom is your controller , bring it back 2 the shop were u bought it 4 a replacement 1 ,. u can also open it up and fix it yourself but if u dont know how , i wouldnt advise it.
Jan 13, 2010 | Microsoft Xbox 360 Wireless Controller
I have an xbox 360 and my controller won't connect but it will turn on the xbox 360 when you hold the button in the middle but still won't connect and i have tried a million time to connect the controller,...
it could be flat?, charge it or get new batteries and try, if that doesnt work you have to hold down the little button at the back of the controller and press the button next to memory unit b on the console
goodluck
Jan 02, 2010 | Microsoft Xbox 360 Controller
Xbox wont connect to controller
something is wrong with your xbox controller coniction to your system
Oct 07, 2009 | Microsoft Xbox 360 Pro System Console
Wireless controller
press the little buton on the controller and the xbox and it should register
Apr 26, 2009 | Microsoft Guitar Hero: Aerosmith with...
My Xbox works but does not recognise controllers
Have you tryed diffrent controllers? like a freinds mabye?
You could try checking the connections from the controller ports to the motherboard on the inside of the xbox.
Mar 29, 2009 | Microsoft Xbox Console
Xbox 360 sync problem - controllers will not connect
maybe the only way is take it a part and see if the sync button is not broken some how. therefore i advise you to buy a new controller maybe even a used 1 if you dont want to spend more than $20.
Mar 28, 2009 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Controller Logo
122 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
