Won't fill with hot or warm water . hot and warm only come out in a trickle. cold water is the water that works normally
  • 1,543 Answers
Turn off water supply valve behind washer and remove the supply hose from both ends. Look for a screened washer in the hose, which can be removed, cleaned, and re-inserted. Also, look for a screen to do the same with inside where the hose screws onto the machine. Re-attact hoses and turn water valves back on. Make sure hoses are not kinked behind machine.
Posted on Feb 01, 2010
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
The cold water comes out on a trickle. the warm & hot settings come out normal. nothing is caught in the line.
check the screens for dirt in the end of the fill hoses and the water inlet valve on the machine. you may need to try replacing the water inlet valve.
Oct 24, 2009 | Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
