My stytem was not connected in the tower so i could not burn any cd's or dvd's nor check my drivers because they did not show up; i have had two different tecks working with me as soon as i do a recovery functio it would lock my computer up and never finished; now that i have the bunier connceted i performed a infotool5 and it had all red x except 1 and had drivers showing in the drop box fir e:/ and f:/; i did not know what to do next to fix the driver problems; had superantispy ware running and did not know what to do next with it; so now i will choose to fix it through you all
  • 11,800 Answers
First of all you need to find the exact composition of your pc - install and run http://www.cpuid.com/pcwizard.php
Once you have fond what are the chips go their manufacturers sites (start with the one of the motherboard) and download (as in Save, not Run) all the drives. Once you have them all burn them to a cd.
Reinstall Windows and install all your drivers. Next allow it to fully update. Next install all the additional hardware: printers, cameras, scanners, etc.
Finally install the security software.
Posted on Feb 01, 2010
Greetings, My DVD duplicator tower only burns cds, Any ideas?
I would say reinstall the drivers for the tower & look for updated drivers from the manufacturer web site. Check all cabling since a bad cable could cause a lot of errors to happen slowing things down. If it was just one drive it could be the drive or a drive is causing the problems. You can disconnect the data cable of one drive at a time to see if the others speed up indicating. Have you installed any software just before the drives started acting up. Other than that I would call tech support of the tower manufacturer. I would assume having it 3 month's your warranty should still be good. Hope you have luck in fixing it.
Bob
Oct 23, 2014 | Computers & Internet
Getting a problem burning 6 files to my dvd. Im get an error after about 2/3 of the burn. tried it with 3 different dvds and one re-writeable. Always getting an error saying to clean the disk or try...
make sure that the dvd burner is getting enough consistent power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 02, 2011 | Pioneer DVD±RW Burner
I have a Pioneer DVR-111 D or DBK or DSV on my PC tower and it's been there for about 2 years. I also had a Sony Burner on the same tower so I could burn from 1 DVD to another. The Sony went out so I...
first make sure that your dvd drive has power. to test just press the eject button. go to device manager, find dvd/cd-rom drives there and expand it. If the pioneer dvr is present and has an exclamation point then just reinstall the driver for that drive. if not there then check in the bios if its there, just got to system information in your bios. If not there then open your tower and unplug and replug the cable connecting your drive to te motherboard. then check again.
Sep 16, 2010 | Pioneer Computers & Internet
My Philips DVD burner doesn't read dvd's
For $40, buy a new CD/DVD reader/writer, and put an end to your problem.
Jul 22, 2010 | Philips SPD2513BD DVD-RAM Burner
DVD RW will no longer burn DVD's
xp should have drivers already check connections
Mar 29, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Cd/Dvd burner stopped working on my laptop
when i try to burn discs i get message connect burner, my laptop is compatible to do all this
Aug 03, 2008 | Dell Inspiron 1000 Notebook
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
24 people viewed this question
jasbo
jasbo
