I have a baxi 130 he combi and my heating is working ok and the indicator for the burner lights up but when i turn the hot water tap on, it goes out and no hot water comes thru, any idea?
  • 36 Answers
Check your diaphram in your divertor,if ok then it may be the flow switch or thermistor
Posted on Feb 01, 2010
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Our Baxi combi 130 HE heats the water OK but will not heat radiators. This has happened after a period of not using the radiators (ie. over the summer)
check the pressure it should be in  the green band, check the pump, inside the boiler cabinet lower right.
Oct 29, 2008 | Heating & Cooling
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
