Question about Emerson Smartset Clock Radio
Can't turn radio off or get anything else to work
Recently had a black out and now there is nothing displayed and I cannot turn the radio off or get anything else to work
  • Anonymous Mar 09, 2008
    Same problem here and also numbers are weird looking. ** buttons work. Have tried taking out battery and reinstalling but ** help.
    President:
  • 814 Answers
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Astra coded radio cant enter code??
I would suggest that your radio got a voltage surge when your battery was recently removed and re-connected. I would either:
1) Remove radio (if you have the special tool), unplug and re-connect harness, or
2) Pull the fuse in the fuse box for the radio (may be two), or
3) Disconnect the negative post to the battery, wait 30 seconds and re-apply (very quickly).
If the display does not reappear, I'm afraid the radio is damaged. Let me know.
Dec 18, 2013 | Car Audio & Video
My Kenwood KDC-U453 cd receiver displays "PROTECT" on connection and nothing works - any solutions appreciated!!!!
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Apr 11, 2013 | Kenwood Kdc-u453 Car Audio Radio Iphone...
Radio worked fine......then I was trying to find another channel by turning the tuner knob and all of a sudden it just locked and when I turn the tuner knob it won't change stations. Nothing works but the...
This may help: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 08, 2011 | Dewalt DC011 AM/FM Radio
My dewalt radio charges, but has no display and wont play anything at all
Try this if the display seems stuck on the same station: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 07, 2011 | Dewalt DC011 AM/FM Radio
I have a dc011 radio and it has no sound. i have checked the 2 fuses and they are good. the power comes on but no sound. Oh and i also have put in the 2 aa bat. what is my next step????? any info will be...
I had this problem recently. If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio or something. And then it works.
Feb 04, 2011 | Dewalt DC011 AM/FM Radio
Jeep rb3 radio not working
i have a problem with myn radio rb3 mijn display he desnt respond but mijn radio works
Sep 07, 2009 | Jeep Liberty RB4 Navigation, AM/FM, CD,...
The radio and cd player work but cannot display anything
hi..make sure that u have turned on the
display button the set.once u have turned
off the display button in your set ur display
doesn't appear.This display option will be
available in the set.
check it out.
thank u.. rate me..
Feb 05, 2009 | 2005 Jeep Grand Cherokee
Emerson Smartset Clock Radio Logo
269 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
