Laptop wont connect to Di-614+
I have a DI-614= running two desktops with adapters.There are two laptops inthe house one being less than three years old and connects to wireless connection with no problem.The other laptop is an older Dell Latitude c840 which was just recently bought from a comptuer supplier that rebuilds or should i say cleans and reformats the system.The problem I have with it is that it will not connect to the dlink. I took this laptop to a wifi hotspot and it picks up internet connection with no problem. Any ideas on maybe compatiable issues or something else.
    President:
  • 2,992 Answers
Since the Dell connects somewhere else, you know its wireless stuff is working. You may have signal issues at home, either low strength or interference. Try repositioning the router. Change its channel through the router setup page to see if that helps. Also be sure you have your security settings right in the laptop. This should get you going.
Posted on Feb 01, 2010
Setup di-614 ip192.168.0.1 without manual. i bought from garage sale
You can download the manual from here: http://www.dlink.com/-/media/Consumer_Products/DI/DI%20614plus/Manual/DI614ManualUS.pdf
Feb 20, 2015 | Computers & Internet
Laptop is not recognizing our home network all of a sudden. We've had the DI-524 for years....do they go bad? Message on laptop says "there might be a problem with 1 or more network adapters." ...
This could be that the wireless card on the laptop was turned off. If you can tell me what kind of laptop it is I may be able to help you check for this problem.
Dec 31, 2010 | D-Link AirPlus DI-524 Wireless Router
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
Connection problems for mac laptop
my opinion would be to reinstal the dsl and d-link drivers that should help bether solution would be to ask youre dsl provider but i think that should help .
p.s.
please rate my solution if you stil have problems write to me
Jul 04, 2009 | D-Link AirPlus DI-614+ Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-524 connection problem
hi.
you need to configure the wireless encryption key on your desktop computer.logon to your router and configure wireless setting and configure your desktop with the same SSID / wep key and it shud connect.post back any errors
Feb 13, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Setup Question
no if your pc is connected to the router, then that one has its connection which i assume will be either usb connected or ethernet connected. You laptop will connect via the wireless connection to the router, not your pc, so as long as your laptop has a wireless adapter then it will independantly connect to the router, your other pc does not have to be switched on as your router is connected to the net as long as it is switched on.
May 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
