Sylvania SSL2006 lcd tv
Set powers up then shuts down after 25-30 seconds. cathode of d309 goes to 9.6 v then set shuts down. I need to know the specs on this zener
  • baladi369 Mar 03, 2008
    Ours does the same thing, but only lasts 7 seconds before powering off.
  • mlnurse66 Mar 16, 2009
    I bought this TV about one yr ago and it just turned off one day after about 30seconds.
I had the same problem the Zener is 9.1v 250mW i just replaced it tvs been working fine
Posted on Aug 27, 2009
Did anyone figure out a solution or did you get rid of the TV?
Posted on Oct 03, 2008
TV sylaviana s/n j27637100, model# ssl2006
maybe you have to buy an electricity regulator (i think thats what its called in english)
if its too old, its overheating and it shuts down.. but i doubt it because 15 seconds its not much.. check if the vents are blocked anyways..
hope that helps
Dec 19, 2007 | Televison & Video
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Tv turns on and stays on for a 30 second then shuts down.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 05, 2011 | Sylvania LC220SS1 22 in. LCD TV
I have a Sylvania LC320SS8 32 in. LCD Television I need the universal remote code for my DishNetwork universal remote that goes with this TV, Do you know the correct code?
Try these codes:632, 569, 556, 506, 525, 536, 566, 568, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729, 733, 756, 764
If you have no luck still try a Power Scan the steps are listed below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Nov 30, 2010 | Sylvania LC320SS8 32 in. LCD Television
Ssl2006 sylvania tv shuts off after a few minutes. Can restart but goes off again. This TV is only used occasionally to watch TV in guest room.
If you always leave it plugged into the wall, it was running 24/7 even if you never turn it on!
It may have power supply problem (bad caps, cold solder joints, etc.) and that will be the first palce to look.
Please read my guide so you will undet stand how TV works.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Nov 25, 2010 | Televison & Video
Barbu51 D309 ck good, power caps look good. TV Syl SSL2006 is completely dead. Circuit board looks over heated around R416/17 & Q402. Don't have print so unable to know what these items vaules are....
Larry,
I was wondering if you ever located the problem in this tv? I have the exact same syptoms right down to the overheated section of the board with R417 and Q402. D309 checks good in mine and the power supply caps are not bulging or leaking at all. Any help would be greatly appreciated.
Ryan
Jan 12, 2010 | Sylvania Televison & Video
Sylvania SSL2006 dead, won't turn on. fuse is ok,
Hi larry
Since you know electronics that will make the explanation simpler;
On your tv model there is a very common problem that you may want to look at;
There is a small board on the right hand side(backlight inverter board),
Look for a shorted D309 , it is a 9.1volts 1watt zener diode.
As i said it is a common problem for your model.
But there is also the power supply;
All lcd tv`s nowadays it seems end up with bad capacitors in the power supply,
You can recognize them by their rounded tops and you`ll find them at the output of the power supply along the 5/12 and 24volts line.
But especially on the 5 volts line.
If your not sure which ones then replace them all (there might be 6 or 7 of them) it won`t hurt and eventually they will go anyway.
Hope this help good luck
Jan 08, 2010 | Sylvania Televison & Video
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
488 people viewed this question
Top Televison & Video Experts
